3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mahogany LED bedside reading light
Bedside reading lights need to be bright enough for reading, but not too bright to disturb a sleeping spouse. For that, a close, directional light works best, but then you can't have a lamp which will heat up and risk burning you... LEDs are the solution. I found these 3 watts LED bulbs which give out the same light as a 20w (and burning hot) halogen. I designed a fixture which I could mount onto my headboard, push up and down and swivel so it can be pushed out of the way against the wall, using mostly ready-made parts because I do not have a shop and my construction skills are quite limited.
Unfortunately, I did not take pictures as I was making it, so this instructable can't go into great detail... however, combined with my instructable for a tin can lamp, it should be fairly easy to reproduce a similar fixture.
Step 1What you'll need
What you\
As you can see in the photos, I made two of these, but the following materials are for a single fixture.
one 18' brass rod with thread on both ends
One 3" brass rod with thread on both ends
Two brass swivels
One metal cup (to use as a frame for the wood)
One Edison base socket with a 1/8" IPS coming out the back
Wire
Electrical tape
One very small toggle switch
Wood tape, preferably 2" wide
Polyurethane, dutch wax, stain, or whatever you want to use to finish the wood
One 3w JDR LED bulb
Whatever I didn't have or couldn't find at the local hardware store I ordered from
www.GrandBrass.com
Google "LED bulbs" and you'll find plenty of suppliers for the bulb.
12 comments
Jul 20, 2011. 8:35 PMjoerice01 says:
Love the headboard panels.
How are the fixed to the wall?
Jul 4, 2011. 6:44 PMporcupinemamma says:
What a "bright " idea! ;0)
Jul 4, 2011. 9:31 AMrimar2000 says:
Excellent work, belsey!
Mar 26, 2009. 12:49 PMevrt says:
Where did you get the friction swivel? I can't find anything like this
Mar 28, 2009. 8:15 AMevrt says:
That's great, thanks! Do you know by chance if anyone makes these parts from stainless steel? I've been searching around but can't seem to find anything
Nov 2, 2008. 10:04 PMChrysN says:
Wow, that looks great, it looks like real wood, not tape. The headboards look really nice too.
Nov 3, 2008. 4:53 PMChrysN says:
I didn't realize, that's pretty cool. You can get it from a hardware store?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
266
Author:belsey
I am trying to work on an overly ambitious tome, MAKE ANYTHING, a handbook for saving money, living green and having fun with trash. Trouble is, I keep getting distracted by pop-ups -- the cards, not ...
more »
