Mail Alarm
1,708
31
4
Posted in TechnologyMicrocontrollers
Introduction: Mail Alarm
About: I like making things, specially if they can move.
After completing my GSM Home Alarm V1.0 and some time of using, I decided to make some modifications.
In the hardware the main changes are the replacement of the ultrasonic sensor and the introduction of a keypad. On the software, I change the SMS notification by e-mail. Also I decided to scale down the circuit and design and 3D print a box for the circuit.
Step 1: Components
Step 2: Connect the Components
The FireBeetle ESP32 IOT Microcontroller will be the brain of this project. The big advantage is that you can get WIFI and Battery management in one very small footprint. It is powered directly from the USB port (+5V) but I also added a battery as backup power (this last one is opcional).
The keypad is connected from pin D2 to pin D8. The led is connected to pin MOSI/IO19. The PIR Sensor signal pin is connected in pin A1/IO39.
A +5V power supply (normal smartphone wall adapter) needs to be connected to the nano USB connector. One +3.7V battery can be also added as backup power.
Step 3: Pushing Box
During this project I discovered this IOT service that allows you to setup several notifications.
1 - Go to https://www.pushingbox.com and create an account.
2- Go to "My Services"
3 - "Add a service"
4 - In "Email" line, press "Select this service".
5- Configure the email that will receive the notification.
6 - Go to "My Scenarios"
7 - Press "Test".
8 - If everything is ok, you should get an email in you inbox.
Step 4: Code
For you to use my code, some changes are necessary.
Define your WIFI network name and password.
Copy the DEVID from "My Scenarios" on Pushingbox and paste it in the code.
Upload and open a Serial Monitor window to check if everything is working.
For activating the system just press "1234", my default password, and the alarm will be armed in 8s (this can be also changed in the code).
Step 5: 3D Files
Step 6: Conclusion
Comparing with my previous project, the upgrade to the PIR sensor is a big improvement. I'm getting almost none of "false, positive" alarm.
Almost in the end phase, I remember, "Why did I not used an RFID???!!!", or better, the Bluetooth module available in the ESP32, instead of the keypad. Also the code is very basic, with a lot of opportunity's of improvement, so I do not think that this will be my last alarm system.
Feel free to comment or send me a message if you found any mistakes, or if you have any suggestions/improvements or questions.
Like it. Subscribe. Make it.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    4 Comments
    Hi very nice project, you could also use Blynk! , I think it's a lot easier! :)
    Duly noted
    Congratulations, this is a very interesting project. A couple of thoughts.
    1) why bother with the keypad? If you just left it running, what is the worst thing that happens? you get a few extra email notifications, right? or am I missing something?
    2) in your code, you mis-spelled length as lenght , you might want to do a search and replace on that
    3) Have you considered adding a small camera to it? I have seen several that connect to Arduino's.
    4) how do you power it? you mention USB but only show the battery backup. An obvious power cable would be a problem because someone could just unplug it. How did you deal with this?
    Thanks!
    Thanks rickatt for you comment.
    1) In fact you are right, but them I would be always getting notifications and I did not want that. I used the keypad to rear the system but I could do it in other way. This is already the 3th version of this project so I think that I will continue doing upgrades :)
    2) Corrected.
    3) I just want to be informed if movement was detected. A camera system is more complex and and for the arduino to handle this probably is not so easy. This would make more sense in a raspberry pi. For now I will keep only with movement.
    4) Again well notice, you can power the ESP32 using a nano usb cable. The battery will only act as backup power. I did a small note in the tutorial for this.
    Thanks for the review :)
