Introduction: Mail Box
for my genius project i decided to make a mailbox with the correct US mail regulations. We were in need of a new mailbox so this worked out just perfectly.
Step 1: Measuring Out the Lines for a Regulated Size Mailbox Post
you need to have the mailbox within 41-45 inches from the road surface. they also have to be set back 6-8 inches away from the curb. we also used another post that the actual mailbox sits on that is perpendicular to the post that goes into the ground. And we used a small plank of wood to put in the bottom of the mailbox that we secured to the perpendicular post.
Step 2: Cutting the Wood
we used a circular saw that had a laser guide for precise cuts
Step 3: Connecting the Two Posts
we cut rectangles into both posts and used wood glue to glue them together then put a screw through it to make sure the glue sticks properly.
Step 4: Add the Mailbox to the Top
then i attached the mailbox to the top of the perpendicular post to make finish off the mailbox.
Stick It! Contest
