3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Maille and Plates Armour
Step 10Strapping your armour
strapping your armour
How you choose to hold your armour shut is up to you, and can range from something as simple(and ugly) as duct taping it to yourself, or as fancy as sneck hooks. I'm going to go for the middle ground and use straps and buckles.
I'm not going to show you have to make straps and buckles here, thats a subject that is better tackled with it's own instructable. Besides, if you've gotten this far I'd hope you can figure out how to make what basically amounts to a small belt.
I will however show you how i strapped my armour, and why.
to start with i ran a strap that goes from the small of my back around my belly under the breastplate. this acts to keep the backplate snug against my back, and in place while I'm doing up the breastplate. once the armour is all done up it doesn't really support anything, so it's only a single half inch strap.
On the breastplate i got a bit fancier. i put the strap mounts just below the top of the side plates and just above my hip bones. from there i ran short straps to D rings mounted on the end of the actual buckle portion of the straps. the pictures should make more sense than my descriptions.
strapping it this way is a bit more complicated than just using 2 buckles on each side, or using 2 straps like the belly strap across my back, but it means that i only have to do up one easy to reach buckle in the small of my back instead of 2 on each side, or 1 easy one in the small of my back and one pain in the ass one between my shoulder blades. also i think it looks cooler.
1 comment
Jun 2, 2008. 3:21 PMcomander01 says:
Have you ever considered making a solid breastplate or greaves to complement your maille?
Jun 8, 2008. 8:04 PMcomander01 says:
Isn't Armour for the forearms called 'bracers'? A coif would also be cool, but that would have to consist entirely of ring maille.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
141
Author:armourkris
