NOTE:If this device fails and you are hurt, i will take no responsibility. Test the device before use.
That said, this is what you need:
1)5 npn transistors
2)wire
3)9v & clip
4)speaker
5)switch
mains protector.fz221 KB
Remove these ads by
Signing UpStep 1Wire the circuit
Wire up using the picture below.
L
What is your aerial like?
L
You could try 4 with headphones.
L
I tried a coil on my first version.
The closer and more surface area the better.
L
I used a coil with 4 inches of turns around a 1cm inch stick.
L
L
