3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Maison Grenouille et Chez Crapaud - vegetable planter built from reclaimed pallets
Step 7The assembly - Et voila!
Okay here a number of steps are covered.
1. Attach the side panels to one another to form a rectangular trough using 8 timber angle brackets (2 at each corner, top & bottom).
2. Using 4 angle brackets, attach the back panels of the frog house at a distance that will accomodate the roof tile or slate (as per schematic). The floor of the trough will rest on the tops of these panels so check to see the finished depth of the trough is sufficient (for instance) to grow carrots. I used 2.5cm x 2.5 cm wooden batons to attatch these as I had run out of angle brackets. Step 8 will illustrate the frog shelter in more detail.
3. Attach 2 grips to the top side of the floor panel. This will allow you to lift the floor panel out of the trough with ease. You will need to make some final trimmings to the floor panel to allow it to slide down the walls of the trough and come to rest on the back panels of the frog shelters. I screwed on some extra bits along this level to create ledges to further support the floor panel.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:fake_faux
