3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make A Breadboard Power Supply
This was a weekend project that I did so I can use a breadboard and get power to it. Some of my projects involve using 5V for a logic supply, while for others I may need a higher voltage. In this instructable I'll show how you can use a fixed voltage regulator as a adjustable one. The advantage of this is method is that your minimum output voltage isnt 2V, such as in the LM317T, but your minimum is what ever voltage regulator you used. For example, in this project I use a LM7805 as a adjustable Regulator, It gave an adjustable Voltage from (Vin-2) to 5V. I say Vin-2, since there is about a 2V drop across the regulator.
The Main reason for making this is because I wanted to make a portable breadboard with a Power supply in case I was bored at someones house, had a circuit with me, and wanted to play with stuff. This orignally stemmed from me salvaging a BUNCH of Mosfets/Transistors and not being able to test them when I was away for a weekend. Thus, this thing is powered from a wallwart or anything that has a 2.5 mm Plug
Step 1The Design
The Design
I needed a PSU that gave both 5V and was adjustable in case I needed 12V. Granted, I could have used a LM317 AND an LM7805, but because Of board space, I couldn't use both. I could have used Just a LM317 Adjustable Voltage regulator, But I didnt feel like breaking out my volt meter if I needed Just 5V.
Then I looked around the web and found that a Fixed voltage regulator can be used as an adjustable version. The reason why this works is that it makes ground "float". By adjusting the pot, your adjusting the ground point seen by the regulator.
The switch shown in the schematic is optional. I removed it from the final design (but its still on the PCB). I later figured I can just remove the power Plug and use that as my switch.
16 comments
Jul 24, 2011. 10:25 PMrwaqar says:
how van i use it to give me -10v ??
Feb 26, 2011. 6:44 PMcomputergeek321 says:
could you use a perfboard
Nov 14, 2009. 1:19 AMJodex says:
Resistors in my local electronics store are so freaking expensive; Almost two euros each! Witch is about 2.8$ !  Once I planned making a guitar distortion pedal and just to spend time I counted how much the resistors will cost on that one and I got about 37€!
Jan 15, 2010. 12:06 PMknektek says:
well what i do is get a schematic of what you are doing and show it to your IT teacher. just say that i need the parts but i dont have them. i got a load of battery holders, caps and pots!
Jan 23, 2010. 5:04 AMoli1122 says:
 Lol iv done that to tis easy make friends with ur DT or IT teacher and say its a project and hes like here's the key to the parts room take what u like LOL XD
Feb 11, 2010. 12:52 PMknektek says:
now im at a place where i can spend £50 on electronics! cool
Mar 26, 2010. 7:33 AMbeehard44 says:
i'm lucky, in the philippines, i know a supplier just 5 minute travel by jeepney and walking. Their resistor costs .25 pesos, about .005 dollars, and well, their breadboard is 120 pesos, or frickin 1 dollar 40 cents
online bullshit cant beat these prices...
BTW, if you do live in the philippines, name is wiltron general merchandise, tel # 8821886 AND i am not advertising them, just for FYI's sake...
Feb 10, 2010. 9:02 PMcdousley says:
 i got the same breadboard, "But the crumbs get stuck in the holes."
Aug 1, 2009. 6:02 AMphillyj says:
When I try to download the schematics, the .sch file is saved as F03P09IFN82TDBA.tmp I just wanted to see it so I'm using Eagle 5.6.0 Light freeware. First time using Eagle also. Any ideas?
Nov 9, 2008. 4:25 AMfrollard says:
Good job on hitting hackaday! Anyhoo, great project - looks like it could be easily laid out on veroboard as well! I need exactly one of these.
Nov 9, 2008. 8:11 AMbearsinthesea says:
nice project!
for people like me w/o mad pcb making skillz, sparkfun sells a kit like this
http://www.sparkfun.com/commerce/product_info.php?products_id=114
http://www.curiousinventor.com/kits/bread_power
Nov 9, 2008. 5:11 AMgmoon says:
Great! Simple, inexpensive and utilitarian (I'd be surprised if commercial versions don't turn up soon.)
BTW, the Instructables interface includes drawing "highlight" boxes overlaying your images. Each box has a mouse-over text box you can customize....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Nerdz
Electronics Engineering Student
