3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make A Breadboard Power Supply
Step 3The Parts
The Parts
Here are the parts per the schematic
1 LM7805 5V regulator (blue box)
1 1k Resistor - this is for the feedback (green box)
1 182 Ohm resistor -this is for the LED (green box)
1 1k Pot - The adjustable resistor used for setting the voltage (red box)
1 LED - any color that isnt too bright
1 680uF 16V Capacitor -(Optional)-Used because the source is more than 6 inches away from the regulator (purple box)
1 1uF 16V Capacitor (optional also) - Same reason, used to help regulation. (purple box)
2 2.54 mm Headers I salvaged from a Old motherboard- These are used to plug in to the board
1 2.5mm Plug. I also salvaged this part, but got it from a old Speaker power supply (the grey box).
Also optional is a small TO-220 heatsink. I added this on for the hell of it since its adjustable (a bit of insurance). If you dont have a heatsink the LM78xx series will shutdown if it gets too hot or if you short the output. You can also use a screw and a peice of aluminum (not aluminum foil!-its too thin) or extra Copper PCB as a heatsink. The heat transfer may not be as good, but its better than nothing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Nerdz
Electronics Engineering Student
