Step 2The Seven Segment Display
Each digit made of seven segments and every segment made of 3 LEDs in parallel.
So a simple calculation gives that there are 21 LEDs in each seven segment display.
And all six digits take 126 LEDs.
But as I said In the parts list you will need 130 LEDs and the other 4 LEDs are going to be used as dots that separate the hours, minutes and the seconds.
I made a common cathode display which means the all the negatives leads are connected together.
Now you will need to choose the right resistor for current limiting to 3 LEDs in parallel.
The calculation is simple and gos like this :
R=(Vcc-Vled)/(Iled*3)
R= the resistor value
Vcc = The voltage that is supplied
Vled = the forward voltage on the LED
Iled =the current the LED takes
You should always take a value a little bit bigger then the one in your calculation just to be on the safe side.
So the first transistor is connected to the first segment ,and the second transistor is connected to the second segment and so on.
I will make a new digram on the weekend but until then I hope my explanation helped.
my email is adil.ali2010@yahoo.com
