Step 5The Base Slats - Construction Phase Two
I. Cut 10 x 63cm slats from the offcut decking planks. Cut one measured piece and then use it as a template for the others. Test fit each one as you go along. See images 2 and 3.
J. Cut out the corners on two slats, so that they fit around the legs in the corners. We drew around an offcut of the legs and made two cuts for each corner with a jigsaw. See Image 4 for a view of the finished cutout.
K. One slat will need two cutouts around the middle legs (we were really lucky and the cutout we needed was exactly the same as the corners, but it may end up in the middle of the slat and need a three side cut with jigsaw). See Image 5 for our finished cutout and Image 6 for a view of the half-size slat.
L. Unless you are really lucky (or work out the initial dimensions based on the slat width) there will be one slat that needs to be narrower than the others to fill in the gap. We cut one slat in half with the circular saw to plug our gap.
M. Place all the slats into the base (see Image 7 for a view of the halfway point).
N. Bask in the glory of completing the woodwork part of construction! See Image 8.
Add Comment
