3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make A Lighted Name Plate Out Of Keyboard Keys
This Instructable will show all of you how to make a lighted name plate out of some scrap keyboard keys and a few electronics.
Let's get started!
Step 1Supply List
Supply List
Here is what you need to complete this project
-Some translucent computer keys, i found mine on an expensive microsoft keyboard broken in the trash
-a battery pack, i used a 2 AAA
-An LED, you could use more i assume, i just used one.
-a switch, so you can turn it off.
-a bit of wire, i used scrap wire
-an altoids tin, or similar tin
3 comments
Mar 30, 2009. 2:45 PMgreensteam says:
I like the concept, not least because I am always looking out for more Keyboard repurposes to add to my list http://www.instructables.com/id/Cyberpunk_Cable_Necklace_101_Uses_for_a_dead_key/
However, although I have keys from about 30 different sorts of keyboards I have not come across your supercool translucent keys.
Apr 8, 2009. 5:33 PMKasm279 says:
if you want transparent keys, you can pull ones off an old Apple USB keyboard or the Apple Pro keyboard, but these are black tinted (the newer ones (that shipped with the iMac G4) have white keys, but im not sure if they are translucent)
Mar 30, 2009. 12:34 PMlemonie says:
On "some ideas for improvements", it would look neater to cut holes in the lid of the tin, and push the rectangular bottom bits of the keys in. As you suggest one LED each would be needed. It looks a bit messy as it is, but you could go with this theme by gluing more bits of junk on to it, so that it looks like a congealed lump of junk where the keys shine through? L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
399
Author:frenzy
I'm the QA engineer here at instructables. I make cool projects in between testing instructables.com to make sure it works awesomely. Give me your bugs!
