3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make A Mini LED Light
Ever find yourself in the dark? A regular sized flashlight too cumbersome? then you need a Mini LED flashlight! You can get these lights at many different stores, but what is the fun in that?
Let's make our own!
Step 1Supplies
You Will Need:
CR2020 battery holder
CR2032 3v battery
Bright White LED
Normally Open Push Button Switch
tools that will help:
Soldering iron
solder
hot glue
work station
9 comments
Nov 30, 2009. 9:40 PMGeekmandude says:
Nice one!
One thing I noticed is that it says a CR2020 holder and a CR2032 battery, wouldn't that be a CR2032 holder?
May 30, 2009. 6:38 AMrobot+more says:
it looks like the deth star from star wars
Mar 5, 2009. 5:08 PMgeeklord says:
3V lithium batteries never sufficiently light up LED's for me....
Mar 25, 2009. 2:15 PMgeeklord says:
I use the LED's that work best on 3.2-3.8 volts and 30 mA. Considering that lithium batteries start out at three volts, it never works out too well. I would much rather use something above three volts with a resistor; I have plenty.
Mar 24, 2009. 6:27 PMnail face says:
how many hours could this last before changing the battery?
Mar 2, 2009. 2:30 PMDantex says:
nice, and small
suggestion - add a key ring to add it to keys so you can find right one =)
Mar 3, 2009. 5:27 PMjtobako says:
Add a CHAIN so you can add it to your keys so you can find the right one : )
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
399
Author:frenzy
I'm the QA engineer here at instructables. I make cool projects in between testing instructables.com to make sure it works awesomely. Give me your bugs!
