In this Instructable, I’ll show you how to make a cheap motion detecting confetti popper using a mousetrap and an air freshener.
Parts list:
Confetti Party Poppers – these are almost always available around New Years or the 4th of July. But if you can’t find them, you can order them here: http://www.amazon.com/OTC-Champagne-Poppers-Dozen/dp/B0008F6O84/
Mouse Trap – Available at most grocery/hardware stores.
Glade Sense And Spray Air Freshener – Available at most grocery stores .You can also buy it here: http://www.amazon.com/Glade-Sense-Spray-Motion-Sensor-Clean/dp/B001V53R4E/
L-Bracket – You can find these at most hardware stores also.
Twine
Binder Clip
Small S-hook
Various Hardware Tools – Drill, Nuts, Bolts, Screwdriver, whatever you deem necessary to make this build easier.
The Concept:
The key to making this project work is the Glade Sense And Spray Air Freshener. It has a motion detector that triggers a plastic arm to move up and down. Basically we will be using this to trigger the mouse trap and pull the string of the party popper.
DISCLAIMER:
Read the warnings on the party poppers, as they should not be pointed at the face. Also, you’ll be working with a mouse trap, so expect to catch your fingers at least once.
Remove these ads by
Signing UpStep 1Modding the Air Freshner
6
comments
Add Comment
iminthebathroom
says:
Add Comment
