3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make A Rotational Casting Machine For Under $150
In this Instructable I will be showing you how to make a rotational casting machine using ordinary items. What you decide to do with the machine after you are done is completely up to you. I will not be held responsible for any inadvertent pregnancies, rodent infestations, snow storms, or sightings of James Dean.
I can tell you that my plan is to use the machine to create hollow casts using urethane molds.
I tried to make the directions as obvious as possible, but clearly my day job is not as an assembly instruction director, so please email me (pseudoreid@gmail.com) if you have any questions that arise during this Instructable. I heavily stress relying on the schematic as your guide.
Step 1The Supplies & Schematic
The totally cost of supplies will be $150 give or take. The most expensive parts are the chain rings ($20 a piece) and the gear chain (about $20).
The schematic I created for the roto cast shows you where things are going to go, but doesn't get into the details. Most importantly, it shows you where the secure and loose joints are going to be.
Here is what you will need.
Tools:
Strong power drill
Full set of high quality drill bits
Pliers or Leatherman
Wrench
Glue gun (w/glue)
Metal/Plastic epoxy (2,500 pounds per square inch strength)
Staple gun
Bicycle gear cutter tool
Hack Saw
Wood Saw
Wood:
2x 20 inch 2x4
1x 25 inch - 2x4
4x 5 inch - 2x4
2x 18 inch - 1x1
2x 16 inch - 1x1
2x 14 inch- 1x1
2x 12 inch- 1x1
Threaded Rod:
2x 4.0 inch - 5/16 inch rod
1x 4.5 inch - 5/16 inch rod
1x 8.5 inch - 5/16 inch rod
1x 3.5 inch - 5/16 inch rod
3x 4.0 inch - 3/8 inch rod
1x 6.0 inch- 3/8 inch rod
1x 12 inch - 3/8 inch rod
1x 3.0 inch - 3/8 inch rod
Hardware:
10x 5/16 inch stop nut
13x 5/16 inch nut
5x 3/8 inch stop nut
5x 3/8 inch nut
Box of 4 inch wood screws
8x 3/8 inch washers (probably will have extra)
8x 5/16 inch washers (probably will have extra)
4x 3.5 inch 22 teeth bicycle chain rings with 4 pre-existing mounting holes, NOT 5
2x 1/8 inch t pipe connector - to support the rotation axle
2x 1/8 inch elbow pipe connectors - to use for the crank
12x L flat brackets used to strengthen joints for frames
3x 3.0 inch flat metal plate with 4 holes in it - this comes in packages of 4, and would normally be used to secure to pieces of wood together. These plates should be able to bolt into the chain ring holes. You will have to drill a whole in the center of the plate though, as there is no existing one there.
14x14 inch piece of mesh
13 comments
Mar 18, 2012. 4:57 PMheathbar64 says:
This is my first introduction to rotocasting. Can you tell us more about the process? It looks like you are just turning the mold over and over so the casting material just coats the inside. Is there more to it that that?
Feb 29, 2012. 1:27 PMVyger says:
It sounds like you were chewing on your vodka infused bacon while you shot the video.
Feb 8, 2011. 2:05 AMstringstretcher says:
waiting.... patiently... for the updates :)
Aug 20, 2010. 4:50 PMmtsawtelle says:
Hey I was just wondering what are the sizes and weights of the molds you have put on the machine? I work with life sized heads a lot, and would like to start using some materials that require a rotational machine. Any information you could give would be a great help. Thanks. M
May 30, 2009. 12:27 PMmfowkes says:
i found that when i made one of these that i needed one of the sprockets to have more teeth, giving the central frame more varied rotations and giving a better, more uniformally hollow cast overall. would you in retrospect make any alterations to your design?
Jan 14, 2009. 5:50 AMsoundmotor says:
The cast rhino head looks great, proof your instructable works! How about another on mixing & coloring resin before the pour?
Jun 8, 2008. 6:27 AMChaz-imus says:
Was that some Crystal Castles playing in the background the song is Crimewave im a huge fan of them
May 20, 2008. 12:54 PMbairdwallace says:
Holy Crap, its the Reider in the hizzouse!
May 17, 2008. 7:06 PMGeordiepom says:
Interesting idea having one sprocket directly driving another. How are these components wearing?
May 15, 2008. 3:22 PMspike shadows (secret agent man) says:
can you show where to mount the molds? I can't really see it anywhere in here
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Pseudoreid
Just a SF local tinkerer, entrepreneur, and artist.
