Step 2Assembling Frames and The Base
As I assembled my frames, I used the glue gun to make the bond that much stronger at the joints. I then used the L brackets to secure the corners to really make the frame strong. I used 8 brackets - front and back -for the bigger frame, and only 4 for the smaller frame, as the smaller frame will eventually have mesh stapled to it, which will strengthen it just as good.
For this step you will also need to construct the base of the roto cast machine. You will need to grab the 30 inch 2x4 piece, and slap the two 20 inch 2x4 pieces on either side of it at a 90 degree angle. I used the glue gun to help secure the connection. You will then also need to attach the 5 inch pieces of 2x4s to every end of the 25 inch plank at a 90 degree angle in order to allow the machine to stand upright without tipping over.
Add Comment
