Step 3Adding the switch
Ok, so inside the amp you have the preamp and two wires going to the speaker. I cut those lines and put a switch on the top of my amp. One set went to the speaker and the other to the horn driver.
Remember to tin the leads on both the wires and the switch before soldering. Pull all four wired through the hole in the preamp assembly. You can use the same wires that were there for the speaker and make the wire for the horn driver 2 feet (you'll see why later).
the switch is wired like any 2pdt switch:
[] [] [] Connect the leads for the amp driver (speaker) to lugs 1 and 2 on this row
[] [] [] Connect the input cables (from the amp itself) to lugs 1 and 2 of this row
[] [] [] Connect the leads for the talk-box driver to lugs 1 and 2 on this row
Best to keep polarities the same (but not absolutely necessary, according to james), just in case there is an issue with the amp. For example I think any class D amplifiers need proper polarization to work... but I might be mistaken.
An interesting addition to this would be a foot controller with an LED indicator, which you could make using similar principles, but add a controller cable, using an electronic switching system and a 1pdt momentary switch on a box that you connect to the rig via a simple switch-cable-jack-e.switch.
