Make A Toy Catamaran
   This project is an easy to build toy boat (catamaran). Yes, there may be a lot of steps, but they are there to add detail and prevent confusion, really this project is not too difficult. This boat is designed to be built with a limited amount of tools and experience. It may not be the fastest design for a boat, but is fairly simple to build and works. It floats evenly in the water and is stable. I hope you give this a try.
Step 1Supplies and Materials
  • last photo ←
   You will need a sheet of  1/4 inch thick wood. It can be plywood or MDF, keep in mind MDF will be heavier. You need a dowel (about 1/4" diameter) or a metal rod. You will need about 5 feet of dowel or metal rod, I used both because my dowel wasn't long enough. In addition, you will need a piece of square wood material (about 3/4" x 3/4" x 18"). I cut a 1 by 2 on my table saw to make this. For the sail you need some cloth and scissors. Solid wire and string is needed to make the rigging.
   For tools you will need a saw to make various cuts. I used a table saw and a chop saw, but a hand saw and coping saw will also be able to make all the cuts. Course grit sandpaper will be use to help shape pieces, a sander will speed up the process. For measuring you will need a ruler, square, and pencil. You also need a way to measure a 45 degree angle, I used my saw which had a laser guide to cut the 45 degree angle. If your square is adjustable, use that, otherwise you have measure out each side of a 45 degree triangle with a ruler (which isn't too hard). A hot glue gun is absolutely necessary. You need a hack saw if you need to cut the a metal rod, and drill bits (one the size of your dowels/rods and a small one about 1/16"). To waterproof the hull I used metal tape, if you don't have metal tape use duct tape or packaging tape. You need a drill driver and screws (8), they need to be about 1 inch long. It is optional but you can also use a small screwdriver and small screws in one of the steps.
30 comments
Dec 26, 2010. 11:48 AM3DMHuff says:
Great 'ible! Two suggestions, one for convienence, one for safety. In step 8: Completing the Hull, when you go to drill the holes for the rods on the square wood blocks, clamp two of them together and drill through both at the same time. Make sure they are lined up straight and you are drilling straight. (use of a bench press is recommended) And don't forget to clean up the kerf.
And #2.
Step 10: Adding the Boom, I would suggest using a slightly larger drill bit to enlarge the hole rather than wiggling the block of wood. The wood could bind on the drill bit, spinning it around. It probably wouldn't kill anyone, but it can break a finger. Or worse, jam one.
Everything else looks great. Looks like something my 7 year old son and I can do one Saturday.
Dec 26, 2010. 12:14 PM3DMHuff says:
You should talk to this guy. http://www.instructables.com/id/The-Happiest-Place-on-Earth-Sorry-Walt/
Dec 11, 2010. 11:11 AMdoodleninja says:
jgjjsalhl
Jul 31, 2010. 6:33 AMknektek says:
I drew a google sketch up of this, its a little bit off but the scale is right. A bit of the pieces are dodgey...
Jul 19, 2010. 8:59 AMerehwon says:
Speaking as a sailor of a full size catamaran I see 3 things which can be done to improve things. First and easiest, a jig sail (in front of the mast) will help the boat point to wind much better. Add a couple of stays on the left and right sides of the mast and one on the front of the mast. Attach the jib to the forestay (front one). You can put a line between the two hulls to attach the forestay to. It'll naturally form a "v" shape under tension, which will help the forestay stay in place. This is how most hobie cats are rigged (I had a hobie 18). Second, your hull design is flat which is going to cause the boat to slip sideways when then wind is coming from the side of the boat. Take a couple of pieces of hard thin plastic and tack them on the side as leeboards. I'm thinking that the plastic "sticks" you get with a starter vegetable plant would work well size size. Anyway, add a pair of rudders (movable or not) and you're done. You can make them of the same material. Third, for the main sail you might want to add battens to help it maintain it's shape. You can probably just add some of those plastic stir sticks you'll find a most coffee places. Add a bit compression tension so they'll want to bend slightly. You'll want to probably add one or two. If one I'd suggest putting it around 2/3rds of the way down the sail from the top tip.
Jul 21, 2010. 1:03 AMkid cudi says:
can you show us how to make the jig and attatch it please
Jul 21, 2010. 8:24 AMerehwon says:
I mis-typed a bit. It should be "jib" not "jig". I'll put together a line drawing and get it posted soon.
Jul 28, 2010. 7:28 AMknektek says:
funny, jib means tongue in another language :P
Jul 26, 2010. 5:06 AMknektek says:
could you add a computer fan for some 'artificial' wind?
Jul 18, 2010. 4:02 PMjimboi$best says:
You should attach some hydrofoils.
Jul 25, 2010. 5:53 AMkid cudi says:
how do you attatch the hydrofoils
Jul 21, 2010. 8:44 AMerehwon says:
Ok, this is a bit of a lame drawing, but hopefully enough to get the point across.
First, with a typical sail boat that uses stays to hold the mast upwards you arrange them as to create a tripod of sorts. There's always one at the front, centered on the centerline of the vessel, and then two which slant backwards towards the sides and rear of the vessel. On a catamaran since you don't have a hull to attach the forestay to you'll have a line which spans the front of the boat between the two hulls. The forestay attaches to the middle of that line, and when under tension the spanning line will form a slight "v" shape (although upside down).
Regarding the picture I've attached (it's lame I know), the "main" picture is a side view of the vessel. I've colored the stays in red, with the hulls and mast being black. The largest and centered image is the view from the side of the boat. The two rear stays attach at the same point near the top of the mast and come down at the same angle to points the same distance back on the hulls. The boats I've sailed generally have these fairly close to the outer edge of the hull. The upper left image is a image of how the spanning line (it has a name but I don't remember offhand what it's called) and the forestay are configured. The hobie 18 I had used two eye hooks near the top inner edge of the hull for attachment points, and the line was not tight, but also not really loose. With the forestay attached to it then you'd have tension, and also the "v" shape I mentioned.
The jib sail I mentioned will be attached to the forestay. The sail on the hobie had a leading edge which would unzip so you could wrap the forestay with the sail, but you can get the same effect with loops of line, or rings. I'd suggest looking for pictures of sailboats on the web for ideas on how to attach one to this model.
Jul 25, 2010. 5:51 AMkid cudi says:
thank you its still kinda confusing as i normally sail moths
Jul 21, 2010. 8:45 AMerehwon says:
Here's the drawing.
Jul 24, 2010. 4:36 AMknektek says:
Can you put some inflatable thing (?!?!) inside of the hulls for more buoyancy?
Jul 19, 2010. 9:33 AMtommy tinker says:
If you cut the sail as in the pic it will make an airfoil shape and be more efficient. Just a thought, nice 'ible'.
Jul 20, 2010. 10:07 AMmccluredb says:
How far out from the original shape should the new one be?
Jul 21, 2010. 5:34 AMtommy tinker says:
I don't remember the exact amount, but I would extend the 'points' about 1/16 of the height and width.
Jul 20, 2010. 1:11 AMkid cudi says:
could you use aeroboard for the hulls as it would be lighter
Jul 21, 2010. 1:01 AMkid cudi says:
it is the stuff used to pack tvs and stuff its very light so it would probably be faster
Jul 15, 2010. 9:41 PMradiorahim says:
I like how in the "Adding the Boom" section there is a boom box in the background.
Jul 18, 2010. 12:03 PMRedRock says:
Cool project
Jul 15, 2010. 7:13 PMbrunoip says:
Great :)
Jul 15, 2010. 6:17 PMChrysN says:
Nice!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:12150w
