3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make A Toy Catamaran
Step 13Attaching the Sail
Attaching the Sail
  • last photo ←
   Drill a hole at the top of the mast, at the bottom of the mast, and at the end of the boom. The holes at the bottom of the mast and the end of the boom need to hold 2 strings. Insert the top end of the mast string into the top mast hole and, insert the bottom end of the mast string into the bottom mast hole. Tie a loop into the bottom mast string after it is through the hole. Stick the top end of the mast string into the bottom loop, pull to tighten. Tie a knot when the string is tight.
   Insert the mast end of the boom string into the bottom mast hole, tie it in place with a knot. Insert the outside end of the boom string into the hole in the boom.
   If you decided to use the out string, insert it into the hole in the boom and at the top of the mast. Tie the ends to keep it in place.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:12150w
