Introduction: Make a Walking Robotic Lego Cyborg! ... ROBOTIC LEGO CYBORG????
I believe I am the first person to ever try doing this, yepee!
I will show you how make a robotic, remote controlled Lego man that walks around, and I bet that this is the second smallest robot of its kind in the world! And I also bet that this is the most craziest robot in the world!
To make this Instructable, you must need a TOMY ROBO-Q robot, and a Lego man.
Step 1: Stuff That You Will Need:
You will need a robo q robot from TOMY and the transmitter, a lego man, a pen(optional), piece of card, scissors, small screwdriver, ruler, tape and a pair of hands!
Step 2: Step 1
Take the leg off lego man...OUCH!
Step 3: Step 2
Unscrew the screw off the side of robo q
Step 4: Step 3
Gently remove the right outer shell...
Step 5: Step 4
The the left outer shell...remember, BE CAREFUL! try not to damage any of the wiring.
Step 6: Step 5
Tape the body of the lego man onto Robo q
As you can see, this does not effect charging at all!
When taping, try to avoid the sensors.
Step 7: Step 6
Using the card, cut this shape. Use the pen to draw it out first if you want.
Step 8: Step 7
Cut another one...
Step 9: Step 8
Tape them on the side of the robo lego man, make sure when taping avoid taping the sensors as well!
These pieces of cards will stop the legs of robo q going out of control.
Step 10: You Are Done!
Congratulations! You have done well if you made this far!
Now just put your Robotic lego cyborg on a flat surface and play around!
Hurricane Lasers Contest
