loading
Step 8: Wrap the bottle with foil...
Cut out a sheet a foil that will wrap nicely around the bottle. Then wrap the foil around the bottle, I used tape to hold the foil onto the bottle. You can use glue if you want, but don't use flammable glue because of sparks, it is likely to catch on fire, or maybe even explode... Then I soothed the foil down onto the bottle to increase the efficiency of the bottle capacitor.
You can use something much much better than foil if you have, use foil tape. You can just simply tape around the bottle and not have a hard time wrapping the bottle with foil and tape (or glue).
<p>hello dude , I wanna make About 100 KV Super Capacitor to use it for Strong Coil Gun , is this battle Capacitor can help or no ?</p>
<p>i am wondering how many you would need to make to use for a coilgun (gaussgun). i would be shooting ball bearings and am hoping for an effective range of at least 30 ft.</p>
<p>Vittu mit&auml; paskaa?</p>
<p>7 years ago risking life for 100 bucks. Huahuahauahau try that again now. </p>
These aren't 100% lethal, but they can really hurt (and make you 100 bucks :) ) There is a way to charge these by turning on the tv with it near the screen, but me and my best friends did this but like 100 times with the tv. I got dared to touch the screw for 100 bucks. I did it, and I fell directly to the ground twitching from like 500,000 volts (tested it with a special tester) going through my chest. I couldn't feel my entire body for like 20 min. and couldn't walk or move for that matter for almost 5 min. but I still got 100 bucks.
WTF!?! You nearly killed your self just to get $100!
yep
Niiiiiiiiice Man!
<strong>; P</strong><br/>
mmmmmm.... 100 bucks.... yummmmm
seriously, that much voltage from a CRT?!?!<br /> i made leyden jars before, but i never thought that mch voltage thru a CRT...<br />
<p>Plenty of tall tales can be found on the internet, right ? :)</p>
A CRT is basically a giant capacitor. When a TV says WARNING, it means it. Be careful with teles.
but 100 bucks &gt; risk of touching a fully loaded leyden jar
<p>Nah his experience was almost all volts, he just got tazed.</p>
wow what has this world come to almost dying just for money ...
<p>charged to 5000,000 volts by merely placing it is close proximity to a CRT? Not likely, even if it was a color CRT, that operates at higher voltages.</p>
Can you use gatorade instead of salt water?
<p>Just to make sure, how long would it take to charge this w/ 6 9v's?</p>
<p>I build one from an old pill bottle I had. Am I correct in thinking that if I charge it with my TV and touch it, it would just feel like getting shocked by somebody?</p>
I'm trying to make a mini one out of an aprox. 2*0.5 plastic cylinder w/ one closed end that I got out of a pen. I've filled it w/ salt water, wrapped it with foil, attached the - wire, and to seal the top, I first put electrical tape over it, then I inserted a small nail, then I put clear Gorilla Glue around it to seal it. I was wondering if this would work, and if it did, how much voltage might it put out? Enough to light an LED?
<p>More like enough to blow up an LED. I guess you found out by now the hard way.</p>
<p>Are these reusable?</p>
can i use a very! very! very! small bottle
<p>Duh, use the same instructions but smaller.</p>
<p>The website that had the directions for the electrostatic charging instructions didn't link properly. I'm not very experienced with capacitors, so what is the maximum voltage, and what is the maximum amperage (power and &quot;battery length&quot;)?</p>
<p>If there is one nail, where are the negative and positive connections?</p>
<p>The foil is the other terminal.</p>
<p>Hi Mr.Plasmana,</p><p>I made my water bottle capacitor and its rating is 1.3uf that's cool and cheap capacitor i ever made; but how to recharge it? Plzzz help me.</p>
<p>what is this good for? What specific application would someone use this on?</p><p>thanks</p>
to slaserj: this is normal . it simply means that the salt and the top electrode created a reaction, taking metal from the nail or wire and drawing it into the solution. look up simple metal plating and youll understand that a little better. if you put copper on the neg of a battery and a quarter on the positive and submerged the 2 in vinegar, youd eventually copper plate the quarter and copper ions were drawn from the copper, through the vinegar and adhere to the positively charged quarter, and youd be left with a solution of copper chloride.
<p>This is great! have you seen any build up of sodium in the bottle's inner surface? </p>
<p>Dear: Plamana</p><p>I am hoping to build my own capacitor but I have to ask you this. You see I am trying to build my own Ionocraft but there are a few problems. Ionocrafts need powerful capacitors but how powerful. So what I am trying to ask you is what is the break down voltage, resistance, watts, volts, amps, and farads of your capacitor. Also how would you determine it with a different capacitor.</p><p>Thanks :)</p><p>From: Noah</p>
<p>can you tell me how much high voltage you give the capacitor </p>
<p>Will this capacitor work with ac current and can i charge it with a flyback transformer</p>
<p>hello, <br>I read about caps replacing batts. hOW DO WE do this? <br>can you come up with an instructable about this ? <br>thanks</p>
<p>i completed this project but the method but the PVC method is more of a exercise than a way to generate static</p>
Thanks for posting this. I built mine and checked my multimeter for capacitance and it's 2.1nF. Cool project!
would it be possible to use this to make an EMP? <br>(Not that I am thinking of making one I am just wondering)
You'll have to use around 8-10 of them.
I hooked three of these in a parallel sequence and got a HUGE discharge
How long will it keep a charge for? Also, how could i disable it if i didn't want it any more?
Hi I built this and it does nothing. Can you help me?
what are you charging it with? <br>
I still think its a neat concept though
This does nothing. I even hooked it up to an AC four wheeler charger.
if you heat the water in a pan then add the salt you could add more
About This Instructable
217,174views
103favorites
License:
Bio: &ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash; &quot;Energy cannot be created nor destroyed!&quot; &ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;
More by Plasmana:How To Build A Simple But Powerful Flyback Driver ZVS Flyback Driver - Video Close ups on electronics
Add instructable to:
