These days you can buy a variety of types and styles in a range of prices and with a few notable exceptions they all work in essentially the same way.
I learned to spin on bottom whorl spindle but tend to use top whorl spindles now. If you know the difference you'll also likely know what you like. This design can be used either way or can be switched between the two styles if you find you need one or the other.
Spindles can be purchased in stores or online for anywhere from $15 or $20 on up to ...a lot. Especially if you want antique or custom "hand crafted" spindles. On the other end of the spectrum you can make them out of rubbish and free things for literally nothing but time.
This will show you how to make a decent looking functional spindle for a few bucks. About $2.50 in this case.
Remove these ads by
Signing UpStep 1What You Will Need
A two ounce block of oven bake polymer clay. I got mine from an art supply store for $1.89. (I chose orange in honor of the spindle being created specifically for an Instructable.)
A chopstick. I used a large bamboo chopstick but you could use any you like. Wood, plastic, bamboo, pretty much anything will work.
A small screw hook. I just had one laying around but you can buy them for pennies or if you sort out how to attach it to the spindle you could make a hook out of a piece of wire.
You will also need:
A working oven to bake the polymer clay. Just follow the directions on the package.
Something to start the hole for the screw eye. A drill bit or an awl should do the trick. If your chopstick is soft enough you won't need anything but most are harder material.
If you're chopstick it too long you'll need a saw or pocket knife to cut it down. Mine was a few inches too long. I used a pocket knife to cut it down. The chopstick started out about 18" long and would have been OK that long but it felt awkward. It would have also made the spindle a little heavier than I wanted.
The whorl should slip fit tight enough to not need anything holding it in place but you might want to grab a rubber band or an "O" ring or something just in case. This is the fourth spindle like this I've made and none have needed anything so far.
The only thing that seems to really matter is that they are well balanced and spin evenly and that you pay attention to how much fiber you are drafting in relation to the weight of the drop spindle. I'd originally planned on making little sockets or depressions to hold coins so I could vary the weight as well but found I like the "pile o drop spindles" approach better.
GREAT!!! thank you for this instructable!! I have wanted to do clay... however whenever i do polymer It is not hard after baking but sort of slightly bendable..
which brand do you like best for hardness?
I am desperately looking for chopsticks, the nice black enamel kind
Or wood, Does anyone know an inexpensive source? I am in vermont.
smiles, grace who collects spindles like potato chips... I make most of them though..
you can re-bake polymer clay, so not all is lost if your first attempt resulted in a piece that's too bendy. just put it back in the oven after you figured out what temperature it actually bakes at and give it another 15 minutes.
for utilitarian stuff like this, i use super sculpey, which comes in 1 lb packs of a translucent pink-beige colour and is much cheaper per oz than the coloured stuff. that's not worth it though if you're just planning to make one whorl; i use it for sculpting, and inside of larger beads. it bakes very hard. otherwise i'd just use whatever is cheapest at your local craft store, it makes no difference for crafting a whorl.
While at myhttp:// www.youtube.com/halalsilks
site, I have a channel called FIBER JOYS and this has hundreds of videos that show spinning on a drop spindle and more.
I also have another channel called KNIT HELP, CROCHET IS TIMELESS and other ones to help others with fiber arts.
enjoy!
Grace
who is equally addicted to spinning
www.instructables.com/id/spinning-yarn/
This type is either just spun by twisting it with your fingers or rolling the shaft along your leg. It's fairly straight forward as far as the spindle goes. It's handling the fiber that gets tricky.
You could probably make one that would spin like a top if you used a much short shaft but this one probably wouldn't spin like that.
I was recently schooled by a little guy, not quite four years old, who was able to point out how to correct a spinning problem I was having. A rare skill that truly transcends age groups.
Nice Instructable!
