Make an Easy Lego Gun.
PlayLEGO by
20,752
13
6
Posted
Introduction: Make an Easy Lego Gun.
In this instructable i will show you how to construct a lego gun that is also compatible with my
Magazine design: www.instructables.com/id/Easy-Lego-Magazine
Step 1: What You Will Need:
The parts needed for this instructable are:
BASE:
1x 10x4 piece.
3x 2x4  piece.
1x 8x1 flat smooth piece.
1x 1x4 flat smooth piece.
2x 1x2 flat smooth piece.
WALLS:
1x 1x20 (make up from smaller pieces)
1x 1x22 flat (to go on top of the above)
1x 1x2 with pin sticking out of the side.
1x 2x20 (make up from smaller pieces)
1x 2x22 flat (to go on top of the above)
1x 2x2 with pin sticking out of the side.
TOP:
1x 4x22 (just make it out of 4x2 bricks and you're fine)
See the picture below, on the left is the base, middle is the walls and right is the top.
Note: the flat bricks aren't in the picture because I'm lazy.
Step 2: Construct the Base.
First, we make the bottom of the gun.
Take all the parts from the BASE parts list and arrange them like in the first picture.
When the gun gets built there will be a gap in between the 6x4 and the 10x4 of 6 spaces for the mag.
Step 3: Make the Walls.
In this step we make the "walls" on the barrel.
You need to take the parts from the WALL list and make a 1x22 piece including the piece with the pin and place a 1x22 flat line on top to form one wall.
The next wall is formed by a 2x22 piece with a 2x22 flat piece on top, try to get the piece with the pin in the same place as the other wall, it doesn't matter if it is off though.
Step 4: Put the Walls Onto the Base.
In this step we will put the walls onto the base.
When you do this, make sure you have the pins facing outward and that you have a 6x1 gap in the base for the magazine.
Step 5: Making the Top.
In this step you put the top onto the gun.
The top is just made out of anything 4 spots wide to cover the top of the gun.
I used a heap of 4x2 bricks, 4x1 bricks and one 4x10 brick.
Step 6: Make the Firing Pin.
All guns need a firing pin!
You need one 1x15 technic piece and one 3 pin long pin.
Place the pin into the technic piece as shown in the second picture.
Step 7: Add in an Extra Brick.
If you look under your gun in the magazine port you will notice a hole 4 spaces wide.
Your magazine is only 3 spaces wide! Get a 1x6 piece and put it on the outside of the side with 2 spaces open. The open parts should now be two with an entry into the barrel in the center.
That's it, your done!
Now go enjoy your newly founded gun!
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    6 Comments
    I would like to announce
    I will likely make my own version of it,
    used under License with the disclaimers and stuff
    I already built it on the computer it
    the article should be ready by labor day
    how do i stop it from jamming?
    my my lego gun that i disigned/invented i found that you have the projectitle smaller then what is just enough to fit into the barrel
    Instead of using the 1 by 1 use those little cylinders instead because they don't hit the sides as much as the other bullets. Explore new bullets
    cool i built it would be cooler if you made a trigger but this is still cool
    the only problem (other than no trigger ) is that if your gonna make a removable mag make it separate from the handle because currently it is more like removable handle
    u should put some king of trigger mech on it. other than that nice gun. where did u get your technic pieces??
