Make Baking Powder
Introduction: Make Baking Powder
That mysterious little ingredient hiding in your pantry, taken out occasionally to help the other, more important, ingredients make a cake. What are you, oh baking powder? You mysterious white powder in a strange container! What are you capable of doing? Why do trustworthy recipes call out for you by name? I mean sure, no one really knows what baking soda is either, but at least it has a bulging arm emblem that immediately recalls strength, and assumingly, a purpose of some sort. But baking powder? No such rapport.
Maybe you already knew that both baking soda and baking powder are used as "levelers" in baked goods which help the dough rise and create a fluffy-ish texture. This is caused by a chemical reaction achieved when moisture is added to the baking powder releasing carbon dioxide, which gets trapped inside tiny air pockets in the dough. (Think sponge cake)
But did you know that you could MAKE baking powder? YUP! And here's another little secret: its made out of baking soda!
Whoa, sit back down. I know its shocking, but just click on, and you'll see the lies unfurl. Baking powder, you have some explaining to do!
Step 1: The Ingredients
Two, sometimes three, ingredients are used to make Baking Powder:
1 part Baking Soda
2 parts Cream of Tartar
(optional) 1 part Corn Starch
Mix it all together in a lie of webs or bowl, if you prefer. Shake it up to make sure it all gets mixed
Step 2: Bake Some Cookies
The bitter taste of truth may not sit well in your mouth, so bake a batch of cookies with your new surplus of baking powder.
Step 3: Storage
Here's another secret: baking powder, whether home-brewed or store bought (hmph. <--contains aluminum, btw. Ever bitten into a tin-tasting muffin? The aluminum additive is where that tin flavor comes from!) can go "bad."
You'll add weeks to the life of your baking powder if you store it, tightly covered, in a cool place. Some experts say its best to store it in the fridge, whereas others say dry pantry is the best bet.
Step 4: Testing
You can test to see if you're baking powder is still potent and fresh by pouring 1/3 cup of boiling water on 1/2 cup of baking powder. It should bubble like crazy if it still has its groove. If the water doesn't move, your baking powder isn't...well, capable of doing the things you previously never knew it could.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    Baking powder is designed to bubble when combined with certain fluids. A double action baking powder consists of a low-temperature acid salt and a high-temperature acid salt. A common low-temperature acid salt is cream of tartar. Almost all high-temperature acid salts are aluminum based, such as SODIUM ALUMINUM SULFATE (which does not, in fact, impart a tin taste). A double-action baking powder, as opposed to a single-action baking powder, will foam up twice. The first time it foams up is when introduced to certain fluids and the second time is when those fluids are heated. Unless you're a very fast baker, your initial foam from this single-action baking powder will die down and your results will be dense.
    Do you happen to know the ratio of baking soda to cream of tartar to alum needed to make "double acting"? I have all three ingredients in my cupboard but I can't find the ratio anywhere.
    I want to make double action baking powder.How can I do that ?
    I may just be twelve but I can bake a mean cake and my mom ran out of baking powder so I came here for help and my cakes are better than ever
    I was wondering about this 2 days ago after watching a show on the collapse of society. I wondered where I would find things like this after there are no more grocery stores!
    The obvious next question is: What about baking soda? Where does it come from?
    Btw, thanks!
    You may find it labeled as Bicarbonate of Soda, or Sodium Bicarbonate.
    Baking soda or sodium bicarbonate can be found in nature because in its natural form, baking soda is known as nahcolite, which is part of the natural mineral natron. However it can be made chemically by heating calcium carbonate
    so it releases CO2....the CO2 vapors are bubbled through an aqueous
    solution (meaning dissolved in water) of ammonia and sodium chloride
    (table salt..dissolved in water)....Sodium bicarbonate will precipitate
    (come out of solution). However I don't recommend doing this at home seeing as how you need to know the proper proportions, temperature, and have the proper apperatus to perform this process.
    Thank you. Maybe I should have asked a different way...
    If society collapses, and as is predicted, grocery stores are cleaned out in the first week, where could i find and gather some baking soda?
    I have to assume that should society collapse, I won't have access to a lab.
    The powder in regular fire extinguishers is Sodium bicarbonate.
