3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make Biodiesel!
Step 7Draining the Glycerin
The main byproduct of biodiesel is glycerin. You put in 20% methanol, and get out 20% glycerin. Glycerin is useful, and can be used to make soap and things. You can also compost it. Just be sure to boil off any leftover methanol before you use it. There may be some unreacted catalyst, too.
After 12-14 hours it should be separated out. Open the valve nearest the tank and make sure the valve on the other side of the drain is closed, then slowly open the drain valve. Drain into a bucket until what's coming out changes color. At this point you've drained the glycerin and have reached the fuel. Drain the fuel into a separate bucket/container.
1 comment
Feb 21, 2012. 4:09 PMQcks says:
Glycerin can be used to distil out a higher proof methanol product.
The less water you have in the Methoxide product, the higher quality the biodiesel you'll produce.
If you can get ahold of sodium peroxide that'd have even less water in the methoxide product.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
125
Author:drinkmorecoffee
I live in a tent just outside of Port Au Prince, in Haiti. Ask me questions. I know the answers.
