Step 1Materials for the Conductive Glue and Circuit
Carbon Graphite, fine powder-Available in larger quantities at http://www.elementalscientific.net/
Available in smaller quantities at your local hardware store. It's called lubricating graphite and comes in small tubes or bottles. The brand I used successfully is called AGS Extra Fine Graphite, but no doubt there are other brands that will also work.
Performix(tm) liquid tape, black-Available at Wal-Mart or http://www.buytape.com
Mixing cups or glass container
1/4 and 1/2 teaspoon measuring spoons
Glass or plastic mixing rod
Cardboard for stencil
Toluol paint thinner (optional)-Available at most hardware stores.
Conductive thread (optional)-Available in larger spools at http://members.shaw.ca/ubik/thread/order.html It is available in smaller spools at
http://www.Inklesspress.com/electronic_parts_2.htm
Circuit materials of your choice
It works well in locks.
If you insist on crushing some graphite yourself, art stores sell sticks of pure graphite for drawing, and some good calligraphy boxed sets come with graphite and a little ceramic bowl for making black "ink".
I need to do some tests with it first...
(this is also very messy stuff for not inhaling)
Otherwise, you need a vac with a HEPA filter which may (or may not) help...
I used it to form MOULDS for my engineering parts, just put some in a tin lid over a home made parafin stove flame (Small) , Mixed with sulpher, becomes very liquid when mixed, Resembles a hard Pencil:
Not too hot or it will burn and ruin the mix and you have to start again:
it goes SOLID in Seconds when in contact with metal, it gave me the female of the bores I was working on, to within micro`s of the original, not much shrinkage at all::
As regarding inhaleing the stuff, I am quite sane and have retired reasonbly healthy, too much scare mongering these days, worked with acetone and that never did any harm either, frightened of their own shadows today..
Asbestos NO..
Jus thought I`d let you all know.
PS: Yes it is Brittle to a point:
As for mixing just keep adding sulphor untill it becomes very runny, but there is a limit to how much you can add.. Try 50/50 for a start, it`s the sulphor that send it liquid.. I made a key in a mould for a bloke at work as he only had one key,, but the firm wanted to see what MODEl it was as they were very expensive and not many made as they were made when you bought the door::
The trouble with it was you could not just take a mould as the nagles went in all directions.. it worked very well. I left it in the jelly mould to keep it safe while it was in the post..lol.
it will mould anything really, it is brittle, but if it`s fairly big it takes some breaking... Best of it is you can use it again.lol...
Have fun.
Colin:UK.
Or is it significantly different than drawing with a pencil?
Care to be more specific, or is this as dangerous as Dihydrogen Monoxide?
