Make Conductive Glue and Glue a Circuit
Step 2Mixing the Glue
Mixing the Glue
After some experimentation, I have found that mixing the Carbon Graphite and liquid tape in a 1-1/2 to 1 ratio by volume, produces the lowest resistance. If you add more graphite than that, the painted line tends to become more brittle and can shrink and crack. An easy way to mix is to use several mixing cups and add 1-1/2 spoonfuls (using a 1/4 teaspoon) of the graphite into each cup. You can then wipe the measuring spoon and then slightly overfill it with the liquid tape. Pour and scrape this into one of the cups and mix up a batch. It is best to mix up one small batch at a time as it tends to dry very quickly and can get gummy fast. Mix it fast and be sure to get all the carbon mixed in well before you use the glass rod or a toothpick to apply it to the circuit you are creating.
WARNING: This process involves nasty solvents in the mixing process. Be sure to mix and apply either outside in the shade or inside in a VERY WELL VENTILATED AREA. Avoid contact with skin until the solvents have completely evaporated (The next day).
4 comments
Aug 8, 2010. 9:58 AMDAVIDJ927 says:
I"m using a mixture of about 3/4 graphite to one part Elmer's glue to repair contact pads in my remote...they could be cleaned no more. So far seems to work fine. Thanks for the tip, I have about 4 bucks in the tube of graphite and glue.
Sep 15, 2010. 4:29 AMastrialkil says:
Is this plane old white Elmer's or the blue jell?
Sep 15, 2010. 5:12 AMDAVIDJ927 says:
Plain old white elmer's, you have to experiment to get proper conductivity, you want a nice black... worked for me! Let me know....
May 16, 2010. 8:29 AMiectyx3c says:
Thank you for sharing your years of experience, I have tried this exactly as you recommend and it works great and is much cheaper and just about as conductive as commercial brands.
For me, the 1.5 to 1 ratio is a tad confusing.
How about just 3 parts graphite to 2 parts liquid tape ?
It amounts to the same thing of course.
* Use a tiny measuring spoon
* Add 3 level spoonfuls of graphite to your mixing cup
* Wipe off the spoon
* Add 2 slightly overfilled spoonfuls of liquid tape
This I'ble is way above average. Good work.
Sep 15, 2010. 4:34 AMastrialkil says:
You got something here! Its more accurate to put in 3 whole spoons then guess at 1.5 spoons as your going to use the same spoon, any spoon and not gunk up your dedicated measuring spoons.
Jun 5, 2008. 9:19 PMnavanax says:
thankyou so much for sharing fruit of your research here it is very helpful!!!
Oct 8, 2009. 6:06 PMptacnik says:
 is te glue flexible it will be really helpfull to know
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
340
Author:mikey77
I believe that the purpose of life is to learn how to do our best and not give in to the weaker way.
