Make Dat Dank Engine Yo Masco G21
Introduction: Make Dat Dank Engine Yo Masco G21
Welcome to the wonderful world of electronics!! Today you will be building an electric motor. It will use a combination of electricity and magnetism to spin magnet wire.
Materials You will need:
1 D Battery (More are optional)
2 paper clips
Magnet Wire (26 gauge recommended)
Sand Paper
Wire Cutters
Step 1: Cutting the Wire
Cut the magnet wire to at least one arms length.
Items Needed:
Magnet Wire
Wire Cutters
Step 2: Wrapping the Wire
Wrap the wire multiple times around the battery leaving both ends of the wire at equal length (close to 2 or 3 inches). This will create a perfectly round circle (coil) with the wire. Carefully slide the wire off the battery without warping the coil.
Items Needed:
Magnet Wire
Step 3: Wrapping the Wire (Continued)
Wrap the straight ends of the wire around the coil until they are the same length and directly opposite each other in relation to the coil. Again, be carefully not to warp the coil.
Items Needed:
Magnet Wire Circle (Created in last Step)
Step 4: Shave the Wire
Shave ONLY ONE of the tails of the wire down until most of the enamel (red coating) comes off and you can see the silver colored wire. Leave some enamel on the wire. DO NOT SAND AROUND THE ENTIRE WIRE. ONLY HALF OF THE WIRE.
Items Needed:
Magnet Wire Circle (created in Step 3)
Sand Paper
Step 5: Making the Frame
Bend the paperclip until it looks like the picture.
Items Needed:
2 Paperclips
Step 6: Assembling the Motor
Wrap the elastic around the battery a couple times, or until it feels tight. Then slide the paperclips between the elastic and battery facing up with the hook part at the top. Make sure the two paperclips are at either end of the battery. Place the magnet, laying flat, on top of the middle of the battery. Place the magnet wire on top of paperclips.(See images above)
Items Needed:
2 Paperclips
Magnet Wire Circle (Created in Step 3)
Step 7: Final Product
End Result:
The magnet wire circle should spin on its own.
If Its Not Spinning:
Give it a little push.
Make sure the shaved part of the wire is shaved all the way down, with only a little coating left on it.
Make sure the straight ends of the wire are dire try opposite each other.
Step 8: Improvements (Optional)
Adding more batteries will increase the charge going through the wire. We recommend a max of 3 batteries. Any more and the wire will start to spark and smoke. Even with 3 batteries, this happens if you leave the motor running for two long. Make sure the batteries are all facing the same direction and are all held together with the elastic. Use a pencil to make a rigid spine so the batteries are secure. You still only need 2 paperclips (one on each end).
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
