Remove these ads by
Signing UpStep 1Cut out your letters
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
Why? so they can do lost foam casting with metal. I can see where you could perhaps use this technique to make the mold.
Have you tried it with other types of foam? I.e. like the pink or blue tight cell foam used for insulation?
What if you just used a squirt bottle to mist the foam with straight acetone?
Again, thank you Mr. Creativeman
P.S. I wish your work shop was mine!
If you are going to put it outside, what coating materials will you use?
I have though since discovered a material -here they call it "alto impacto" (if I got it right through the wiki in English its called HIPS or High Impact Polystyrene) - which should be able to do the job outside in not to high temp regions. Here you get them from 0,5mm onwards which cuts very easily and is 1/5 the price of Plexiglas...
Since I used acetone rather than spraypaint, the paper's color was removed, but it still removed very easily, and created clear letters.
