3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make Foam Look Like Carved Granite!
I like to make signs, so when I saw an excellent instructable on making foam "sandblasted" signs, my ears perked up! I make them too, but have what I think is a simpler method. Check it out.
Step 1Cut out your letters
In this step, you make the letters to be used for the resist. The letters prevent the foam from dissolving, much the same as in sandblasting. I use my word processing program to print out the message I want to use. The letters are easily cut out with scissors as seen in the picture.
60 comments
1-40 of 60next »
Jan 19, 2009. 7:15 AMClayOgre says:
Do you realize what you've got here? I have seen stuff on the net where people have gone to great lengths to build CNC milling machines to cut foam.
Why? so they can do lost foam casting with metal. I can see where you could perhaps use this technique to make the mold.
Have you tried it with other types of foam? I.e. like the pink or blue tight cell foam used for insulation?
What if you just used a squirt bottle to mist the foam with straight acetone?
Oct 5, 2011. 12:38 PMstringstretcher says:
pieces that are cast are usually over dimensioned and worked up later using milling machines and the like. This may well work for certain applications! Cool!
Jan 20, 2009. 10:37 AMClayOgre says:
hmmm, enough control. Well, then if one were to use it for metal casting, then each object cast would be one of a kind, which would have it's own possibilities.
Jan 19, 2009. 8:45 AMmaruawe says:
You can use acetone,but it melts foam really fast , I use it to melt foam to make led rocks( button battery and led taped together ,then covered in the melted foam,and rolled into shape desired). Don't know what to mix acetone with to dilute the mixture (a little help on that one if you please) but that would help.
Jan 19, 2009. 5:08 PMClayOgre says:
If you look on youtube, there are vids of people doing lost foam. In fact, one of them is a guy who has several vids of taking one of those foam skulls they sell at Halloween time and using it to cast a funky aluminum trailer hitch decoration for a pickup truck.
Aug 24, 2010. 12:46 PMKoevoet92 says:
I know I'm a bit out of date here but I simply wanted to thank Creativeman for this great idea, my second Instructable I've started (1st, 3'd, 4'th still in progress :S ) that is now officially finished.Wife and I have a little cake shop and I used this idea to make a 1m x 1m board with all the cake fillings we offer.
Again, thank you Mr. Creativeman
P.S. I wish your work shop was mine!
Jan 20, 2011. 7:00 AMHernando says:
I love your sign!
If you are going to put it outside, what coating materials will you use?
Jan 20, 2011. 2:15 PMKoevoet92 says:
Thx for the compliment! but no, its inside our shop.
I have though since discovered a material -here they call it "alto impacto" (if I got it right through the wiki in English its called HIPS or High Impact Polystyrene) - which should be able to do the job outside in not to high temp regions. Here you get them from 0,5mm onwards which cuts very easily and is 1/5 the price of Plexiglas...
Jan 2, 2010. 6:49 AMsomebody demon says:
great   i will try it   thanks a lot
Dec 31, 2009. 7:54 PMSarahBellum says:
Thanks for the great ideas! Using my standard printer, I printed my text from a word document on to adhesive shelf liner (Con-tact Paper). First I cut a piece of the paper to standard 8 1/2 by 11.  So that the letters maintained accurate spacing I cut out everything using scissors and an exacto, but left a tiny line connecting each letter at the bottom. I easily clipped that off after it was layed out on the foam.
Since I used acetone rather than spraypaint, the paper's color was removed, but it still removed very easily, and created clear letters.
May 31, 2009. 4:58 PMCreaturiste says:
Hey, this is very cool! A combination of concepts I knew separately, brought together by you, for an efficient effect! Thanks! Now, how do we protect our foam sign from wear and tear? Foam is easy to bump and chip off. I'm a paper mache specialist, so I know two layers of paper towels and diluted glue will hold on quite well, but that would hage the texture quite a bit. Any good idea with common materials? I know about Rosco Foamcoat, and even Sculpt or Coat, but I'd prefer a finish that isn't palstic-like...
Dec 2, 2009. 8:36 AMrobsrad says:
i saw this instructable and automatically thought of creativemans other instructable about making letters in concrete. So to make it more durable i was thinking of putting the letters on backwards then useing that as a form to pour colored concrete over. I will definitly be trying this out as a christmas present. Nice job creativeman.
Nov 13, 2009. 4:23 AMkcli says:
Glad to see this in the Halloween entries...good luck in the contest!
Aug 16, 2009. 4:19 PMpiaferre says:
this is SO usefull!! so simple and great results, thanks for sharing =)
Apr 14, 2009. 6:59 AMQuiff says:
Very nice. Is there an easy method of removal of the masking so the underneath (masked) part stays smooth? Have you tried 77 spray glue on the masking rather than white glue and if so, did it remove cleanly?
Jul 9, 2009. 9:42 AMjontjack says:
77 spray glue will desolve the foam as well, that has been my experience. I bought 'special foam glue' once and it was just white glue. White glue worked very well for a project of mine that stacked 10 layers of foam to form a block.
Apr 21, 2009. 9:47 AMlawdog323 says:
what is resist paper Creativeman?? I love this idea. Very simple yet an awesome outcome..
Mar 25, 2009. 2:01 AMnatethegreat88 says:
I remember when I was like 7years old and was in cub scouts and we had to make a rocket that would travel along a clothesline kind of like a pinewood derby. the block i got was foam and when i was done sanding I spray painted it with spray paint that had cetone in it and it ate away my whole ship and so it looked like a black crumpled up peice of trash.
Apr 4, 2009. 8:10 AMLindaLW666 says:
...and you still worry about it. now that you're 17. Look, I'll buy you another, okay? Love, LW
Mar 25, 2009. 8:02 AMneubaten says:
that made me feel all sad and wistful, like a scene from gummo or something. le sigh....
Mar 11, 2009. 3:16 AMLori Ell says:
How clever. I love to see how creative and clever people are. Really beautiful. People who do skits and plays will love this. The stone discs are awesome. Thanks for sharing!!
Jan 24, 2009. 7:16 PMMrPumpernickel says:
1. Ensure for good ventilation, 2. Wear a mask. The fumes that comes from chemically burning foam is bloody nasty and may over time cause respiratory problems.
Jan 25, 2009. 5:38 PMMrPumpernickel says:
My muse always told me "That's a worthless way to look at things, if you can't take and give criticism you might as well stay at home under the sheets and never do anything with your life." But that's a sideline and really has nothing to do with this. Either way, I don't see how what I wrote is not "constructive", it's basic safety tips which I hope anyone that tries what you wrote about takes seriously. I like the instructable, just wish you'd make an addendum so people understand to do this at the very least where it's well ventilated. I'm sure you don't want to cause anyone to do undue harm to themselves, right? We had a guy here at university who did something similar in the workshop a couple of months ago, he ended up passing out and spent three days in the poisoning unit at the hospital, hence it deserves to be taken seriously.
Jan 26, 2009. 12:16 AMMrPumpernickel says:
I don't know, if sense was in any way common we wouldn't have warning labels on chainsaws that read "Don't attempt to stop chain with hands" and so forth.
Feb 26, 2009. 12:37 PMamywho says:
MrPumpernickel. Thank you for pointing out the obvious. I too hold this thing we call 'common sense,' but not everyone has it. The older I get the more I've learned that the greater population aren't really born with common sense. If everyone had it, there would be no such thing as the Darwin Awards. Unsure of the reference? Google it. And the children, creativeman. Thing about the children....just because they're not SUPPOSED to try something like this alone, doesn't mean they wont....
Mar 11, 2009. 3:11 AMdianakob2 says:
Thanks for the heads up. I have to agree...if people used common sense, they wouldn't have need to put "contents are hot" on the McDonald's coffee cups to let people know that if you put it between your legs and it spill...you're probably going to get burnt! BTW, the Darwin Awards are a riot!
Feb 6, 2009. 8:04 AMcloudhidden says:
I really liked the idea. How does this hold up for exterior use?
Jan 22, 2009. 3:03 PMhammer9876 says:
Excellent. A lot easier than sitting around carving "R. I. P." in a block of foam. The eating away part reminds me of the neighborhood kid that just wanted a little bit of gasoline for use in our summer project. He wasn't too bright, however, because he used the garden hose and sucked some gas out of tank of his car. (Kids, don't try this at home!) When the gas started coming out, he directed the liquid to a Styrofoam cup - which instantly dissolved. Made quite an impression on me. He went on to major in Chemistry in college. Better life through chemistry.
Jan 22, 2009. 11:31 AMmogimbu says:
I made Mayan Stone Disk prop with a simalia rmethod a few years ago. The insulation foam I used has a layer of plastic cling on it. I cut out the design, then pulled off the area to be etched. I was able to use an inexpensive plant sprayer to apply acetone to the piece. I like your method as you can skip one step of painting. Well done.
Jan 21, 2009. 10:55 AMduck-lemon says:
This is great, wonderful use of supplies and resources. That's some very creative work there creative man! **subscribed**
Jan 21, 2009. 4:16 AMKEUrban says:
Great idea... A good combination of technique and creativity!
1-40 of 60next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
638
Author:Creativeman
Retired, doing art work now. Great. Have the time and the money to spend doing what I want to do.
