Step 2Shredding the Foil
Once you are done, you're ready for the fun.
All Steps Viewing
I can only say that the same method does not work for everyone, I do apologize for wasting your time.
as for shreeding the foill, just use scissors, but be sure to wipe the blade every 4-5 cuts becuase aluminium powder builds up on them and that prevents a clean cut, instead it just tears the foil .
by the way randyclark747 what kind of mill did you use? did you halve fill the barrel with sbb's and did you reduce the gear ratio, becuase running a dc motor with a barrel capable of grinding the alumiunium foil, with gears only reduced to halfe speed will almost always burn out, unless its a lego/gear head motor which has stepped down 4-5 times inside itself
if your looking for motors with gears built inside look at jarcar.com they have huge torques, but im not sure how exactly you make the mill from that, just have a go, they have 50kg@55rpm torque and only cost about $20
if possible, you can attach the barrel directly to the motor and it will run fine no probs.
by the way, i am making an instructable on making a 1L capacity lego ball mill from lego and a pvc pipe, keep a look out its nearly finnished, the way it works is like an upside down car with the barrel rolling on the tires
__O__
|O O|
thats basicly what it looks like , with the barrel being the top "O"
How did you go about shredding the foil?
