3 Simple Ways to
Share What You Make
Other ways to share:
How To Properly Cut Down A Bottle (Simple&Video)
by
nepheron
Upcycled Paper Bead Earrings
by
TabbyDeAnne
Uber High-end Fashion Earrings from Recycled Water Bottle
by
Lftndbt
How to Make Paper Beads
by
Mzuribeads
Recycled Broken Glass Lamp
by
fozzy13
How to turn your old liquor bottles into desk lamps
by
Hank_2k
Repurposed Etched Glass Spice Jars...
by
WUVIE
49,729
views
Related: lampworking, recycle, upcycle, glass, beads, bead making, cheap, free, glass bottles
Comments: 189
Rating: 4.3
© 2012 Instructables
All Steps Viewing
Nice instructable for recycling the colored glass, Thanks!!
Please explain the whole bail wire thing. It sounds fascinating! I've never in my life heard of that before!!!
How did you stretch the wire? Did you have to stretch it far?
It is very important to keep methods from dying.
Certain glassworking skills have been forgotten over the eons, and this may be one of them. I like collect these methods and keep them alive. Pass on the knowledge!
Thank you!!!!!!!!
-Nepheron
When it's red hot, you can pull on the ends to stretch it.
You might have some success (if you don't get around to making your own!)
by searching for Troll, Pandora, or Biagi beads, or their knockoffs.
(they're specifically made large hole beads, the holes go from 3.5 mm to 5 mm, fits on most cording & chain,
Good Luck!
for those who want something dressier than a #2 pencil...
B^)
Mike
Also, allow the plaster to cure onto the rod. This make take 3 hours!
Apply the plaster in a thin layer or it will crack off in the flame...it will take some fidding to get right! If the plaster is too thin...the bead won't come off...
Good luck!
how does the glass stick to stainless steel or aluminum? or is the melting of point of aluminum lower then glass?
and does this affect the color of glass when it sticks to metal?
does the glass bond to the metal because the metal is porous and the glass fills in the pores? or does something else cause the glass to bond to the metal?
I'd be concerned about the noxious fumes from aluminum.
The glass will likely flake off those surfaces, but it WILL change color.
other than that I have no idea. It sounds like you are talking about cloisonné, which is not my specialty.
-Nepheron
http://www.glassline.net/forums/showthread.php?p=728
Art
If you are going to flame dry, even with flame dry release, you hold the mandrel high over the flame so that it gently warms the release, turning the mandrel constantly so that you get even heating. the process takes only a minute more and you get much sturdier release and not much chance of super heated water vapour popping the release onto you.
it's important to have a sturdy release so that if you want to start doing things like making flowers in the glass, which involves a lot of dot work and some pushing with a tungsten pick, you don't have the release crack and the bead forever sticking to the mandrel.
Fireworks, Bucket O Mud, and Fosterfire all have "wet to torch" products.
However, it's not "stick it in the fire" ready, you've got to slowly burn off the water & vapor, or yes, you'll have the problem mentioned above.
No different than introducing the glass too fast. Pop. Ouch.
I slowly evaporate the water, then I'm good to go.
If you use plaster as a release, DO NOT flame dry it...it explodes LOL
The videos are great in demonstrating how long it takes to do each step, and how much time the glass should spend in the flame at each stage.
