loading
loading
video Make Glow Sticks - The Science
We show how to make glow sticks and go through all the chemicals needed as well as how to make different colors. We also talk about the chemistry and scientifically research a proposed mechanism.
To make the glow stick mix together the following:
10mL Diethyl Phthalate (solvent)
3mg of fluorescent dye (see below)
50mg TCPO (see below)
100mg sodium acetate
3mL 30% hydrogen peroxide (add last to start reaction)
The fluorescent dye can be 9,10-bis(phenylethynyl)anthracene for green, Rubrene for yellow, 9,10-diphenylanthracene for blue, and rhodamine B for red.
TCPO is expensive to buy but can be made for much cheaper by following the directions in our previous video: http://www.youtube.com/watch?v=ViJknvEEEOA
The chemicals, including the ones to make TCPO were purchased from alfa aesar:
The Rhodamine B and Rubrene dyes were instead purchased from sigma Aldrich:
The dyes and TCPO are carcinogenic and gloves should be worn when handling them.
The TCPO and sodium acetate amounts can be varied considerably and still obtain good light. Smaller quantities tend to be dimmer and decay faster, while larger quantities last longer.
For those that want a kit that has all the chemicals, there is kickstarter for that:
NOTE: I am not in anyway affiliated with the company. I cannot vouch for the effectiveness or quality of their product.
1-40 of 75Next »
Can you make these in any other colours other than these four?? Please and thanks for any responses :)
KhoiN13 months ago
can u just make me one Im only 15 years old
opps i made it three times
wait......... so um you can make glow sticks out of water well im a fourth grader and i really need help on my science project because it's on 2 MONTHS and i can't think of something thank you so much for giving me this great idea !!!
Solion10 months ago
Simple question , what dye is used for infrared glow sticks as used in the military markers. They are great illuminators for nightvision / IR camera gear
cjlopez2134 years ago
How long do they usually last? I'm currently using UV fluorescent dye for a display at my house but can't seem to get white would it be possible to apply the same method you used to get white with the dyes? thanks for the instructable looking forward to making some
For how long it last all depends on the quality of chemicals you use in it...
As for getting a White Illumination I can't seem to find much info on it, but I do know that the white glow-sticks actually use a Blue or Purple dye to get the white color, almost like adding Bluing to Luandry to whiten clothes...
me1me2me33 years ago
hey do you live in texas
If your asking NerdRage, no he lives in Canada...
Ari353 years ago
Hi Guys, Can I use Luminol instead of using TCPO??
Thank You :))
A Quote from NerdRage on a prior comment:
"For something a bit cheaper and safer I recommend looking into luminol based chemiluminescent reactions. Luminol can be bought online relatively cheaply compared to TCPO. and you don't need unusual solvents and dyes to use it..."
cosmoz2 years ago
Dr NurdRage,
Esteemed, colleague. Thank you for the great videos-- instructive and very interesting. Great voice, too. I have an odd question, and it has to do with a pending science project. Is there any chemical you might recommend to increase the viscosity of the glow stick solution? We are looking for a constancy something like maple syrup. Of course, taste is not a consideration, and no one will be eating this stuff. Also, is over the counter Hydrogen Peroxide of sufficient potency as a reagent? Thanks again. Science Rocks, Sincerely, CosmoZ
Small amounts of unflavored Powdered Gelatin might work as a thickener agent... But always try a small batch first to make sure that some adverse side effect does not occur...
As for "Over the Counter Hydrogen Peroxide..." The stuff won't work... The kind of stuff you get via the First Aid and such is only 3% concentration, not the 30% needed... You could concentrate it by freezing it, but that is a somewhat tricky procedure as the freezing points Of Hydrogen Peroxide and water are so Close... A quick search on Google will tell you how to do this best...
I believe the Hydrogen Peroxide for Bleaching hair is closer to 6-10%% so you might be able to pick some of that up to use instead, and concentrate it...
Anyways, I know this might be an old post but I hope that I was at least a little help...
i need help to buy all the material for my scienes project and i want to buy the TCPO and not make it some one help me plz ??
ikuto3 years ago
Is there more then 1 typ of TCPO?
DNPO (bis(2,4-dinitrophenyl) oxalate) and CPPO (Bis-[2,4,5-trichloro-6-(pentyloxycarbonyl)phenyl]oxalate) can be used. Mountain Dew CANNOT be used.
cayuse2 years ago
on this wikipedia article http://en.wikipedia.org/wiki/TCPO it says that it is also called "Oxalic acid", which alfa aesar sells in a few different solutions for a lot less than TCPO, which is over $100/gram.
I do not have access to the equipment or supervision to attempt to make TCPO, and don't really care to deal with or attempt to acquire deadly chemicals.
Will any of these solutions work for this reaction, would you use it without the solvent? or is that solvent for the dye?
Thanks for your comments, and some very interesting chemistry.
NurdRage (author)  cayuse2 years ago
That wikipedia article is wrong. it's not also called oxalic acid. Oxalic acid cannot be used as a substitute.
for something a bit cheaper and safer i recommend looking into luminol based chemiluminescent reactions. Luminol can be bought online relatively cheaply compared to TCPO. and you don't need unusual solvents and dyes to use it.
jamob2 years ago
woah deep voice lol very cool
jumper174 years ago
NurdRage- I showed this method to a group of friends (his father is some sort of chemist, and allowed me to use some materials) and they found it most amusing. I also used it to mark boundaries, the jail, and the flag location during a round of night capture the flag, as well as other sports that required a little fluorescent lighting. Again, thank you for making this instructable!
(PS has anyone told you that your voice sounds like the protagonist of "Sanatarium"? Well, it did to me)
Thanks again.
abellizzi4 years ago
NurdRage- I set up the equation in molecular formula. Where did the chlorine product come from. Since you add Hydrogen Peroxide, Dye, and Cyalume (or TCPO for you), the end product is trichlorophenol, dye, and Carbon dioxide...where does the Cl come from?
Thanks
NurdRage (author)  abellizzi4 years ago
TCPO and cyalume are not the same thing.
kingpwnzer4 years ago
Very nice, i enjoyed watching this im going to have to try this out later on, good instructable (:
Isurvival4 years ago
The best glowsticks i have ever seen! Great job!
Roxy 1434 years ago
This is awesome and worth trying !!!
GeekusN844 years ago
This is, by far, my favorite Instructable so far after several months of lurking. Good on ya! I also have a few questions: Is it possible to make non-toxic glow sticks, like the ones that can sometimes be found at the store? Is there even such a thing as a truly non-toxic glow stick? Can these chemicals be used in a common plastic container, such as a water bottle, or do they need a particular type of plastic for storage and use when glowing? Again, great video!
NurdRage (author)  GeekusN844 years ago
The ones in the store are not "non-toxic" as they claim. they do contain very similar chemicals to what i use here. They can get away with labeling it like that because not that dangerous in small doses. Like a single cigarette isn't going to kill you, but you shouldn't do it. I do understand why they do it though, if they labeled it as "slightly toxic" or "Do not drink" people will panic and think it's death in a bottle and won't buy it. Public perception of danger is weird like that. Unfortunately labeling it non-toxic makes people think they can drink it as party stunts and be perfectly fine, when they really shouldn't be doing that.
wolfcrow5 years ago
I was wondering... Could the chemicals in a highlighter be used instead of the dyes used in the clip?
I would imagine they can not. As mentioned in the video, the dyes must be fluorescent meaning that when energized they emit light. Although they are flourescent in color, the chemicals in the highlighters lack the ability to flouresce. (Just Guessing)
JTMON Schober4 years ago
Well, they sorta work but only fluoresce under UV black lights.
robm9995 years ago
Which dye would be used to produce infrared light?
NurdRage (author)  robm9995 years ago
To be honest i don't know. But it DOES exist. I saw a military glowstick once, looked completely normal, just a lump of plastic to the naked eye but when you looked at it through an infrared camera it lit up the entire room like broad daylight. The military uses it so soldiers can mark their position, or signal aircraft and other soldiers with infrared gear.
I think they just use a visible light emitting dye, and make the plastic casing out of plastic which filters visible wavelengths. Sometimes the dye mix is in the vial and the "activation solution" is the bulk of the fluid.
NurdRage (author)  deejman4 years ago
No it is an actual dye that emits in the infrared and not in visible I've seen the emission spectra plot and it clearly has its peak beyond the visible range with nothing in it.
crooki4 years ago
where can i buy these components???
NurdRage (author)  crooki4 years ago
Video description not working for ya?
1-40 of 75Next »
