Make Laser Cut Acrylic Box With Nuts and Screws
Published
Introduction: Make Laser Cut Acrylic Box With Nuts and Screws
This instructable shows how to build a laser cut acrylic box with embedded nuts, which can be fastened by flat head screw.
I've used polycarbonate nuts. This nut is transparent and can be bonded to acrylic with acrylic cement.
Step 1: Cut Acrylic Pieces
When design the case, prepare holes for screws and slot for nut.
Step 2: Bond Nut to Acrylic Piece
Push nut in place, add a small drop of cement to bond the nut. Don't add too much as it may go inside and melt thread.
It would be better to test the nut before you bond it. If the nut is not working, it will be hard to take it off.
Step 3: Create Countersunk Hole
we can use a countersink bit to drill a countersunk hole for flat head screw.
This is pretty straight forward as there is already a hole. You just need to make sure the depth is correct.
Step 4: Bond Interlock Edges
For the interlock edges. I use rubber band to hold everything together and bond them with cements.
Step 5: Fasten Box With Screws
Fasten the box with screws!
Screw should rest in countersunk hole and holds the nut.
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
