Introduction: Make Nitric Acid Using Electricity and Air !
In this instructable I will show you how to do the correct wiring for the Nitric acid reactor shown in the video above
Step 1: Watch the Video
In the video you will get a general overview about the project and how it goes.
Step 2: The Wiring of the The CFL to the The Transformer
1- First you must Identify the windings on your flyback transformer , the easiest thing to do is to check the circuit board of your TV if it has any marking , or perhaps google any writings on the transformer itself .... It that is a not an option, there is a load of videos online showing how to Identify the primary and secondary on a flyback transformer like this one :
[Play Video]
Step 3: AC Mains to CFL Ballast
Picture of AC Mains to CFL Ballast
Connect the AC plug to the CFL ballast circuit as shown and place screw-on terminals to 8the output of the ballast
Step 4: CFL Ballast Output to Flyback
Picture of CFL Ballast Output to Flyback
The long black wires coming out of the ballast should hook up to the primary of the flyback transformer ( the polarity doesn't matter )
Step 5: Attaching the Ground Wire and Final Preparations
Picture of Attaching the Ground Wire and Final Preparations
Attach the ground wire to the ground pin and you are good to go and create arcs !
Step 6: The Reactor in Working Order
This is showing the reactor after assembling everything together
About This Instructable
2,548views
13favorites
License:
More by PseudoGeber:Jump Start Your Car Using Small Lead Acid Battery (Cheap Alternative to Li-Ion Jumpstarter Packs) Make Nitric Acid Using Electricity and Air !
Add instructable to:
