Make Nitric acid - The Complete Guide
video Make Nitric acid - The Complete Guide
We show 3 ways to make nitric acid based on two different chemical approaches both of which can be done using easily accessible materials.
Warning: The procedures in this video produce large quantities of toxic gases and deal with highly corrosive acids. All work must be performed in a fume hood with proper safety equipment. And all apparatus must be glass to withstand the acids.
Chemically, nitric acid is made by bubbling nitrogen dioxide into water. So the objective in this approach is to generate nitrogen dioxide. This can be done by reacting hydrochloric acid, a nitrate salt and copper. Around 80grams of sodium nitrate, over 30 grams of copper and 100mL of hydrochloric acid are the quantities needed. The exact amount is not critical. For useable concentrations, the amount of water being converted should be small, around 20-50mL.
Any source of nitrate is usable including potassium nitrate, ammonium nitrate and even nitrate-based fertilizers. You can use our previous video on testing for nitrates if you want to determine if yours can be used. http://www.youtube.com/watch?v=f5M3rUqaEYs
The tricky part now is leading the gas into water. Two approaches are shown in the video. In the first approach three containers, such as jars are place inside each other to force the gas to go into the water. This is very inefficient but is very simple to do.
The better approach is to lead the gas out of the generator through a tube and into a chilled container of water.
The water that is converted into nitric acid can be replaced with hydrogen peroxide for better yield.
The chemical waste that is generated contains the valuable copper used before and recovering it is worthwhile due to todays high copper prices. This is simply done by putting in enough aluminum metal that it reacts with all the acids and copper in solution to create a slurry of copper. This can be filtered to obtain a residue of copper. it is highly contaminated but can still be used to make more nitric acid.
Finally, the last way of making pure nitric acid is to react concentrated sulfuric acid and a pure nitrate salt (NOT fertilizer) and heat it in a glass distillation apparatus to distill over the pure nitric acid. Stochiometric quantities of both reagents are recommended for maximum yield.
We get our glassware from chemglass or VWR
If you like our video, please check our others at http://www.youtube.com/nurdrage
55 comments
1-40 of 55next »
Jan 20, 2012. 12:07 PMShutterBugger says:
I just discovered http://www.sciencemadness.org/ and it's "Energetic Materials" section, where you can find TONS of interesting chemistry.
There is also a very interesting "The Los Alamos Technical Reports Collection" section.
~Bob~
Jan 6, 2012. 6:42 PMBornOnFire says:
Last check, Nitric Acid was available online for $30.00 per liter. Might be not only a cheaper solution for some folks but also a SAFER one. especially for those who do not have a fume hood handy. Just sayin......
Jan 6, 2012. 8:31 PMBornOnFire says:
Not trying to be a downer. I was just stating that to perhaps give people perspective. Especially for people like me who would probably burn the house down if attempted at home. I actually admire your project and love the science as well. Nicely done!
Apr 4, 2011. 1:02 AMmadmans firework emporium says:
just two questions,
1, if if nitric acid is the only one strong enough to dissolve copper, what does ferric chloride do to PCBs?
2 can you kill two birds with one stone andetch a PCB in the hydrochloric/nitrate
Jan 9, 2011. 9:41 PMcraigkrekorian says:
Thank you for a great demonstration.
I have been interested in this type of chemistry for a long time.
Nitric acid is used in the mining industry and in machine shop processes.
I have had a few uses in the past for this acid in both of these industries, but did not have this knowledge or an easy way to obtain it then.
Rest assured, I will use this responsibly and safely.
Keep up the great work ;-)
Jan 9, 2011. 9:28 AMblacksmithedpony says:
A drop of nitric acid is what i needed to test the purity of some silver tid bits I've had laying around. Was relieved to find that you'd made this ible. Simple steps and low cost, much thanks
Jun 4, 2009. 3:55 PMThe Ideanator says:
wow, that was easier then i thought it would be, just dont mix the highly concentrated stuff and Hexamine, it might get some people upset (the government)
Apr 14, 2010. 10:16 PMqualia says:
rofl. rdx ftw
Jun 4, 2009. 2:00 PMlemonie says:
Oooh, this might be nice but it's all wrong (in principle). Nitric acid is made from ammonia, and nitrates are made from that, so you're going backwards here... Is there anyway of burning ammonia in the lab? L
Apr 14, 2010. 10:09 PMqualia says:
bravo.
Jan 14, 2010. 11:56 PMPerankhscribe says:
A good article describing this process is here:
http://www.epa.gov/ttnchie1/ap42/ch08/final/c08s08.pdf
Honestly I think Lemonie is missing the point here.  The approach NurdRage is demonstrating is a very useful reaction for an amateur chemist.   I did want to note however that you can get platinum off ebay which is extremely pure.   Now rhodium is another matter, but if you have the platinum you can do it.
Electrical arcing....  It does work but its inefficient and contaminated.   If I am not mistaken there is some ammonia produced by the arcing method.   Free radicals also tend to react and make more complicated products.  (They say this is how the building blocks of life were made.)
yeah because platinum isn't expensive at all.
Jan 26, 2010. 5:47 PMJaycub says:
I don't see how ammonia would be made in a berkland eyed reactor... but yeah lemonie is deffinately not saying a true thing. Nitrate salts can be made by microorganisms and extracted from the dirt they live in (then converted to hno3 and k2so4 by reaction with h2so4), or nitric acid can be made from ammonia which was made in the haber process (or whatever way it was made), and there's always the BE reactor. There's nothing wrong with Nurdrage's ways.
Jun 4, 2009. 2:52 PMlemonie says:
My thinking was along the lines of: nitrate & nitric acid equilibrate, so if you add hydrochloric acid to nitrate you're done in that step. But more than that, if you've got the fume hood, proper safety equipment and all apparatus you've got a bottle of nitric acid in your lab anyway (and you have I know). It's nice to see but isn't really practical. I've seen US army handbooks on improvised munitions explain how to concentrate (car) battery-acid, produce nitric, make nitrating mixture, improvise explosives etc - I do get it. I'm just being picky on a point of principle, nothing more than that - I like this stuff! L
Sep 1, 2009. 7:14 PMJaycub says:
"...if you add hydrochloric acid to nitrate you're done in that step." Does this mean that I could just mix kno3 with muriatic acid and it would be nitric acid even without the bubbling step?
Sep 1, 2009. 11:11 PMlemonie says:
Yes. But that wouldn't give you concentrated nitric acid.
L
Sep 2, 2009. 8:43 AMJaycub says:
If I boiled the water out of the muriatic acid and mixed concentrated hydrochloric acid with the kno3 would the nitric acid be stronger? Then could I distill it to make it even stronger? My bubbling experiment didn't work very well.
Sep 2, 2009. 10:44 AMlemonie says:
Theoretically yes, but these things equilibrate and stuff. What do you want nitric acid for anyway? L
Sep 2, 2009. 11:45 AMJaycub says:
There are a lot of uses for it, mostly explosives.
Sep 2, 2009. 12:18 PMlemonie says:
Often with sulphuric (concentrated) so why not use that? L
Sep 2, 2009. 12:21 PMJaycub says:
My first experiment will be nitrocellulose, then urea nitrate. And anyway I need more supplies before I can make sulfuric acid.
Sep 2, 2009. 12:32 PMlemonie says:
Nitric acid will happily hydrolyse cellulose if it's too wet, but you might be able to find some celluloid somewhere (wikipedia it for uses as a material)
L
Jan 14, 2010. 11:58 PMPerankhscribe says:
Agreed.   These people are going to hurt themselves or somebody else.
Sep 2, 2009. 12:10 PMJaycub says:
Not for weapons, just for fun.
Sep 2, 2009. 12:16 PMJaycub says:
I'm not a terrorist!!! They only kill or maime if you use them wrong. I just really like fireworks.
Sep 3, 2009. 3:15 PMJaycub says:
It also might make you feel better to know that I am not only making explosives. I will also be experimenting with rockets, and mabey to extract pure gold from dirt.
Sep 2, 2009. 1:06 PMJaycub says:
I'm not planning on making anything much bigger than a few ounces, so the wors that could realy happen with the precautions I take is a fire or an injured hand. What specificaly am I getting wrong?
Jul 14, 2011. 3:21 PMjonjones48 says:
in most states any explosive over 1.4 gram in mass is illegal without permit. Making and then storing ANY AMOUNT of explosive without a license is illegal in ALL states!
This, is the reaction I got after making and using copper(i)acetylide
Jul 14, 2011. 10:45 PMJaycub says:
Mabey your technically right but I've read that The BATF will "look the other way" if your just making flash powder or something for recreation.
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
570
Author:NurdRage(NurdRage)
NurdRage is a dedicate group of science nerds trying to further amateur science with direct how-to instructions in video format. We saw what was already online and we thought "we could do better"... s...
more »
