This can be used to create anything you like recipe cards, gardening tip cards, gift tags, notepaper, stationary, etc., and makes a very thoughtful gift.
I have found several methods on doing this but none of them seemed to work quite right for me, so through a lot of trial and error and finding a few tricks of my own I was able to get a more desired effect from my project.
Make sure to have removed any foreign objects such as staples, stamps, glue strips, etc., and check your paper for any hint of slick or shine which indicates a varnish has been applied to it and it should not be used.
Remove these ads by
Signing UpStep 1Materials
An old wooden picture frame or make a frame to your desired size
Fine Window or Door Screen Material
A Staple Gun or Heavy Duty Tacks
Old Terry Cloth Towels
White Towels (not terry cloth 2 per sheet of paper)
Baking Sheets
Cooling Racks like you would use for cookies
Bricks or something to add weight
A Blender
A Rolling Pin
A Plastic Container, larger than your frame
A Pitcher
Waxed Paper
Any kind of small flat flower or vegetable seeds, I used tomato seeds for this project.
"What would you recommend for a vegan replacement to the gelatin? Would agar-agar work?"
Is agar-agar similar in chemical composition to bone or hair?
Agar-agar is from seaweed, but what chemicals are most of the bulk?
Does agar-agar help strengthen fingernails and hair? If so, it could be a source of chemicals which supply nitrogen.
I'm sure other people would be glad to hear of your findings. Try "nutritional comparison gelatin vs agar-agar" in the Google. Hope you find something!
1) The space between each seed must be taken in consideration because if they are too close each other when the plant grows up they will fight for minerals and like final result you will get two or more weak plants furthermore some may die.
2 ) Keep in mind the germination rate, this means that no 100% of the seeds that you place on the paper will germinate. Typ for a supermarket seed is 80% or less check the manufacture if is longer than one year you rate will drop to 40%, (search for other option)
3) Are you planning to use this paper only to germinate the seed and after 28 days you will transplant to another place (for bigger space) or this is going to be the final position of the plant?
keep in mind the space requirements for an adult plant for example tomato needs at least 1 foot around the root and a lettuce only needs 6 inches
I hope it helps you
