Step 9Warnings To Read Carefully
- An all-meat diet can quickly become frightfully unbalanced. Unless you understand feline nutrition, it is imperative that you follow the recipe without alteration or substitution. Many of us frequently prepare foods for ourselves and skip an ingredient we don't have on hand. You cannot do this in a proper feline diet. If you do not have all of the ingredients or cannot obtain all of the ingredients, don't try this. Nutritional deficiencies are much easier to cause than cure.
- Don't microwave this food. This is especially true if you've used bones in your recipe. Cooked bones splinter and can be very dangerous to a cat. Raw bones are soft and are easily digested by a cat. Just warm it under warm water in a baggie
- Never risk feeding food that is slightly "off" or spoiled. Chances are your cat won't touch it in that condition, but to be safe, work out a thawing routine whereby the food you're about to serve is still just ever-so-slightly frozen. It's easy enough to complete the thawing quickly by running the food in a baggie under warm water to take off the chill, and this way you're assured that the food has not gone "bad" from being thawed for too long.
- Don't over-do the use of "bribe foods" on top of raw to get your cat eating the raw food. Lots of tuna juice, for example, is a big no-no, as the flavor is so powerful that your cat may refuse anything that isn't tuna flavored later on. But a sprinkle of their favorite old commercial food is fine.
- Some vitamins, are water-soluble, which means if you use more than the recommended amount, you're not putting your cat at risk for toxicity, as any over supply of water-soluble vitamins will be excreted. It's also possible to "over-dose" your cat on other vitamins. Some ingredients are a "polish" to the diet while others are not "supplements" at all, but are absolutely essential components that must be included in the ratios and amounts specified or you risk throwing your cat's diet dangerously off balance.
- Salmonella and e. coli infections are very real risks when feeding raw diets. If a cat develops one of these infections, the people in the household especially children are at risk as well. It is well known that raw eggs can be contaminated with salmonella, as can poultry.
- Intestinal parasites are also a concern; parasites can form cysts in the muscle tissue of livestock. Consider keeping your cat on parasite prevention available from your veterinarian.
- Raw meat carries a high risk of toxoplasmosis for your cat. Toxoplasmosis can be deadly for unborn babies, and may cause problems later in life, including schizophrenia. If you are pregnant or thinking of becoming pregnant, it is important not to switch to a raw meat diet as this can infect your cat and then infect you when you clean her litterbox.
Add Comment
