Make: Robot Hotglue Injection Mold
496
8
5
Posted
Introduction: Make: Robot Hotglue Injection Mold
Make: Magazine has one of the most famous maker or hobbyist mascots ever. His name is Makey, and now you can Make: Millions of Make robots with a hot glue injection mold! With the time of making these cute mascots lowered, now you can make more than ever before! The two mold pieces print in about 1 hour and 45 minutes total, and then you can start producing like mad!
Once you are done, please post a make on both instructables and thingiverse( http://www.thingiverse.com/thing:796654 ) so I can see how yours came out!
Step 1: Step 1: 3D Printing the Files
whether you have a 3D printer or not, you must first 3D print the files somehow. In order to print them, you need a at least 20X20X20mm bed for the files as individual prints, but for the "E-Z setup" you need a 100X100X100mm print area.
If you don't have a 3D printer, then i would recommend shapeways ( https://www.shapeways.com/?utm_source=google&utm_m... ) or 3D Hubs( https://www.3dhubs.com ).
the prints together take about 1 hour and forty-five minutes.
Step 2: Step 2: Injecting a Mold!
First, Spray your mold with cooking oil so that the model is easier to take out. If you have a multi-heat hot-glue gun, then set it on "low" setting, and let it heat. If you do not have a multi-heat hot-glue gun, then just turn it on and let it heat. Then, clamp the two pieces of the mold together, making sure to align the pins. Next, you place a layered piece of tin foil (a piece of tin foil folded over itself) with a hole in it. This is so the mold doesn't melt (I learned that the hard way...). Then, inject the glue into the mold until some starts to pour out of the air release hole. After, wait 20-40 minutes for the mold to cool. Then, simply pry of the front of the mold. And then finaly, you use a screw-driver or your finger to pull the model out of the mold.
Enjoy!
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    • Microcontroller Contest
    5 Comments
    You can clean up the "stringy" bits on your hot glue models with careful use of an ordinary lighter. I use the technique on dolls shoes and it smooths them down really well. Just go slowly or you may end up with a BLOB. LOLS - which you can always remelt anyway.......
    Nice. I love molding with hot glue because it is so easy to rework and modify.
    Thanks! would you like me to post the 123d design files of a blank mold so you can make your own?
    Thank you! i also have a Minecraft character mold on thingiverse that i will publish here too! :)
