3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make Skeeball-inspired Games Using Pizza Boxes, Party Favors, and a PC
Step 2Construct the pizza box’s base
As you build your base, you'll be using your supply of non-pizza-box cardboard. One or more of the images will correspond with each bullet point of this step:
*Start by selecting some cardboard to serve as the base.
(Feel free to tape pieces of cardboard together until you have a piece as wide as the pizza box and longer than the opened box.)
*Mark and cut the lines that represent what will become your pizza box ramp support structure. Fold them upright when cut.
*Lift the lid of your pizza box to about 45 degrees. Find a piece of cardboard that matches the width of your pizza box and is a little taller than the lid you're lifting.
Cut a hole in the bottom of that piece that will fit your keyboard. Remove notches from the top of it so that it can function as a slot in a tab you'll make in the next step.
Note: I tinkered with an initial prototype of this project until I arrived at a structure that satisfied me (just stable and reliable enough). I built the more-stable version I'm describing by looking at the parts of the initial prototype. I did not work from exact measurements. I do not mention many measurements in this instructable as I hope that the pictures will help you "eyeball" measure the materials you find. You'll notice that I try to refer to the size of most parts with respect to the things to which they connect.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:amonmillner
