Pictured is one of a set of TV trays I made for my wife. Most sets contain four trays. She wanted six.
Materials required are--
1/2 inch A-D grade fir plywood
Plastic countertop laminate
Plastic laminate adhesive
Good hardwood of your choice for legs and trim
Hardwood dowels
Wood glue
Aluminum bar stock
Brass woodscrews
Wood and sheetmetal screws
Varnish or shellac
Tools required are--
A tablesaw or a radial arm saw
A router with a corner rounding bit and a laminate trimming bit
A bandsaw or a sabre saw.
A drill
A chisel for scraping
Screwdrivers (straight and offset straight)
Sandpaper
An inexpensive paint brush for applying laminate adhesive
A hammer and a wood block
"C" clamps
Remove these ads by
Signing UpStep 1: Making the tray top
Begin by cutting pieces of 1/2 inch plywood 14 3/4 inches by 21 inches, one piece for each TV tray you want to make. Some solid wood trim will bring the tops up to the dimensions mentioned in the paragraph above, but that is for a later step. The edges of the plywood should be smooth. There should be no splintering or kicking up of the grain on the top "A" surface of the plywood. I chose to have the "A" side up so the plastic laminate would be glued to a nice smooth surface.
Visit Our Store »
Go Pro Today »
I was thinking that the planking may break if someone put too much weight on it, but no one would put that much weight on it anyway. I might make some support underneath just in case though.
I also never tried the newspaper method with contact glue (cement), I always used 3 square rods to position the laminate, then I remove the center one and press down to make the first contact so the sides won't move, and finally a J roller working my way from the center outwords to avoid air bubles.
I will give a try to your method given the chance.
Thanks
Steli
You have given me a couple of good ideas for ours, nice one :-)
Excellent instructable, as always!
I recall seeing someone recommend using strips and/or sheets of brown paper bag between two items to be joined with contact cement. I figured it would work fine but brown bags are rare in stores anymore. ;)
You are right about TV tray tables. They are small. We had some cheap TV trays pressed from thin steel with thin steel tube legs. Those disappeared somewhere. My wife asked for TV trays, and I made these.
Those things serve me for the last 5 years and never had the need of the dinning table.
Job very well done
Stelios
