3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket Speakers
Step 3Assemble and Solder
Assemble and Solder
This step is fairly easy, simply thread all three wires through the holes in the plastic, or tape/glue them to the tin if you didn't have a plastic cover. And solder all 2 - 4 points. Generic stereo jacks from headphones have two wires, and two more in each one. (I'm not much of an electronic savvy guy so I'll let other people correct me here) The non insulated inner wire is ground and the insulated one is the power supplying one. I've found that it doesn't matter which one goes where on simple speakers (by testing normal and reverse connections) so solder away.
*Side note, if you haven't already, any sort of computer speaker usually comes with a little plastic end that helps connect the wires to the pins on the motherboard. You can take this off by using an Exacto knife or pin to press down the locks on one side of the plastic end and pull individual wires out. Unfortunately these things are rather small, especially on two wire pin connections and coming from a laptop. My camera was unable to take a photo of these little things (even with macro).
6 comments
Aug 7, 2009. 7:18 AMhoppe_groda says:
when i cut my cable up, it had four unisolated wires in it , one green, a red and two copper colored ones, how should they run????
Jan 29, 2012. 4:03 AMivanjacob says:
red is right green is left the 2 copper ones are -
Sep 21, 2009. 7:12 PMwangtrevor says:
... that mean u have 2 speaker sides green and copper1 for left or right earbud and red and copper for the other
Sep 5, 2009. 8:01 PMMazdaSpeedProduction says:
Thats excattly mine! I'm confused!
Dec 15, 2010. 3:44 AMxxxcrossxxx says:
currently the speaker is running on the power supplied by the ipod, can anyone suggest how can i supply power externally
pls help
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Gonazar
