Make Worm Food for Your Wormery
3,547
57
Published
Introduction: Make Worm Food for Your Wormery
We love our wormery! It's a great way of turning small amounts of kitchen waste and shredded paper into fantastic, nutrient-rich compost that our allotment vegetables love. Worm farming is also called vermiculture. It's a fancy name for a very un-fancy activity! But it's worth it, because the resultant fertile compost is amazing.
Worms don't sound like the ideal pet, but they are. They need little in the way of care or maintenance, and your friendly little worms will consume your waste and convert it into plant food for you. We are grateful to our worms, so we decided that it was time their tired-looking home had an upgrade, we did this here https://www.instructables.com/id/Make-Or-Upgrade-A-...
Now its time to feed our wormery and get the worms breeding so that we can add a lot of material.
How to Feed Your Worms - reference http://www.recycleworks.org/compost/wormfood.html
Select foods that are suitable for worms including most fruits, vegetables, cereals and grains, and other organic items like cardboard and tea bags. It is best to cut food scraps into small pieces before placing them in the bin. The smaller the pieces the more surface area there is for bacteria to start breaking down the food, making it easier for the worms to consume. Some people put their food scraps, including eggshells, into a blender and make a slurry. The worms seem to love this, but it is not necessary. Keep shredded black and white newspaper over the food at all times. Newspaper or bedding helps keep the bin dark and moist and discourages fruit flies. Other organic material such as burlap or shredded cardboard or paperboard can also be used. The worms live in these materials and they also eat them. To feed the worms, place the food under the newspaper in a different part of the bin each time. Do not bury the food in the castings.
How Much Food?
Worms need to adjust to their new home and new foods so do not overfeed them the first few weeks. In addition to the food you are giving them, they're eating their new bedding. Once they are settled, comfortable and happy they will quickly munch through their food. The bin will require more food as its population grows. You want to feed the worms just ahead of their rate of consumption.
Before adding new food, consider:
Have they had enough time to consume old food?
Is there food remaining because they do not like it?
Has the food not been broken down enough by bacteria for the worms to consume it?
If there is a little food left and the worms are eating, additional food can be added. But if food is left due to one of the other reasons, cover it with newspaper and don't feed again for a week or remove the food from the bin.
Feeding Schedule
Unlike other critters, worms don't demand to be fed on a schedule. They can be fed once a day, every two or three days, or once a week. You can go on vacation for a month without worrying about them. Just give them a regular amount of food before you leave and place plenty of shredded newspaper, cardboard or paperboard on top of the food. Make sure you leave the bin in an area where the temperature will not get too hot (not over 90º) and the cover material is wet enough that it will not dry out.
Happy redworms will eat half their weight in food every day. That doesn't sound like a very large quantity of food because they're so small, but when you get a few thousand worms living in a bin, food disappears rather quickly.
Other Additions
Because worms have no teeth, they need to take in grit with their food. Rock dust or crushed oyster shells offer grit for their diet and can also help correct problems if you've added too much food to the bin. These can be purchased at most garden stores. To add these powders to the bin, sprinkle a small amount on the food scraps once or twice a month. Pulverized eggshells are an excellent source of grit. If you are adding eggshells to your bin you probably won't need to purchase other types of grit.
Trouble Shooting Problem:
Moldy food Solution: If you have fed the worms too much, the food might become moldy. Remove moldy food as worms are unlikely to eat it and it makes the system vulnerable to infestations from other microorganisms. Problem: Offensive odor Solution: Uneaten food has become anaerobic. Make sure there is a generous amount of damp newspaper or cardboard placed over the food and stop feeding for a week. Add rock dust or crushed oyster shells.
Problem: Worms trying to escape
Solution: Bin may be too wet or too dry. Add more dry bedding if too wet, or moisten bedding if too dry.
Examples of Worm Food Fruit: apples, pears, banana peels, strawberries, peaches and all melons Vegetables: beans, cabbage, celery, carrots, cucumbers, tomatoes, all greens, corn, corncobs and squash Cereals and grains: oatmeal, pasta, rice, non–sugared breakfast cereals, corn meal, pancakes Miscellaneous: coffee filter paper, tea bags, eggshells, dead flowers
Other food/bedding: newspaper (no shiny or coated paper), cardboard, paperboard, paper egg cartons, brown leaves
Use Caution When Adding These Breads — can attract red mites Potato skins, onions, garlic, ginger — get consumed slowly and can cause odors Coffee grounds — too many will make the bin acidic
Do Not Feed Meat, poultry, fish, dairy — protein attracts rodents Potato chips, candy, oils — worms do not like junk food and these attract ants
Oranges, lemons, limes — citrus has a chemical substance (limonene) that is toxic to worms
Definite No–No's in a Worm Bin Non–biodegradable materials that do not belong in your bin include plastic, rubber bands, sponges, aluminum foil, glass, and dog or cat feces.
Step 1: Chop New and Old Veg Into Chunks Small Enough to Be Blended
Chop all the veg into chunks that will fit into the blender. I use a 2 cm cubes as this allows the veg to move around inside the blending jug and process quicker.
Step 2: Blend Veg Chunks and Add Charcoal
Add veg material, eggs shells, charcoal or rock dust, tea bags and other organic material identified in the intro. Blend with water to ensure it can move in the blender as a wet mixture will not over stress your blender motor.
Step 3: Collect Blended Worm Food
I like to collect my food in a bucket as I typically make quiet a lot of food for the wormery at the end of each week. You can see in the pictures the change in colour as different vegetables and material is added.
Step 4: Add Shredded Paper to Absorb Excess Water
I add shredded paper because the worms like to have bedding material mixed with there food, it also absorbs some of the water I added in the previous step. It helps aerate the mixture an allow the right bacteria to grow for the worms. I will keep some of the food back and add it every other day during the week. Do not let it get smelly, If it dies add more shredded paper and mix.
At the end of the week keep a little back so that you have a culture of bacteria ready to help the next load of food.
Keep on worming!
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    2 Comments
    ☺️I mean white threadlike worms, sorry - Petra
    this article was very informative as I am new to a worm farm. I noticed this week fine threadlike with worms. Should I be concerned about that as it may be an infestation of some other kind of insect?
