Make Your Own Invisible Earphones (including Step by Step Video)
282,990
623
190
Published
Introduction: Make Your Own Invisible Earphones (including Step by Step Video)
About: Living in the center of the world factory FrankGuYun@gmail.com
The video step by step tutorial
It is better to watch this video in HD formats.
How to use this invisible earphones?
        First you need to put a tiny magnet in one of  your ears or put two in both of  your ears. Then you need to wear a coil necklace which is connected with an amplifier. Next connect your mp3 player to the amplifier.  Cover the coil necklace and the amplifier properly with your clothes.Turn it on. Now you can enjoy music without being noticed by other people. You can use another small magnet to get it out.  This sort of Invisible headphones is sold on ebay.
 Warning
 Warning
(Warning : Don't put the magnet deeply in your ear. Although there is no medical proof that says magnets will cause trouble to your ear , it's better not to use this device for a long time. Magnetic fields can disrupt the operation of some internal medical devices such as pacemakers.Neodymium magnets are made with special powders and coatings, so they are very fragile. They are often plated with a metal such as nickel. The magnets can fracture at temperatures over 150 °C, or under impact as a result of their own acceleration. When this happens, in some cases the magnets may break apart so suddenly that flying pieces can cause injury.
Make sure that there are no magnets around you, when you use this device. These magnets can move with surprising force when exposed to another magnet or magnetic field.
If you don't know what you can do with this device. please watch this video. (Just for Fun
Step 1: How Invisible Earphones Work
As you know, in a normal speaker. The magnet stays still.  The coil vibrates producing sound. Unlike the normal speaker, when this device is working , the coil necklace which is around your neck stays still.  The magnet vibrates in your ear producing sound.
Step 2: Find the Proper Magnet for Your Project
I' ve tested magnets of different sizes. And I might find the best size for this project. You can buy this sort of magnets on ebay by searching the key word "  Neodymium magnet" .  Actually, there is a resonance frequency.  The bigger the magnet is, the lower resonance frequency you'll get.
Step 3: How to Make the Coil Necklace Part.1
What you will need: 1. cardboard
                                     2.enamelled wire  ( Length=50meters  Diameter=0.25millimeter )
Enamelled wire is a kind copper wire which is coated with Polyurethane. I use a cardboard to wind the coil necklace. Make sure the diameter of  this coil necklace is larger than the diameter of your head.  The resistance of  the coil I made is about 23ohm.
Step 4: How to Make the Coil Necklace Part.2
Cover the coil necklace with tape to protect it.   In order to connect the wire to the amplifier., you need to solder on the tip of  the wire. So  you need to use a knife to get rid of the plastic layer on the tip of the wire.
Step 5: The Amplifier
The LM386 is the power amplifier.  The power supply consists of two 9 volts battery. Actually , there are there types of LM386. According to the datasheet, only LM386-4 can work with 18 volts power supply.  I find out that LM386-1 can also work for at least 10 minutes  with 18 volts power supply. But I am not sure how long it will work.
Component List :
            Capacitors  220uF      X 1
                                  10uF        X 1
                                  100nF      X 1
                                  47nF         X 1
            resistors     10 ohm    X 1
                                  1k ohm    X 1
           LM386                            X 1
           9 volts battery                X 2
Step 6: Final Assembly
Put the tiny magnet in one of  your ear. Connect the coil necklace to the amplifier .  Put on the coil necklace.  Turn it on.
If  you succeed in making this device , you can send me a e-mail with the picture of your work. I'll put the picture at the end of  this tutorial.
3 People Made This Project!
  • Planter Challenge
    Planter Challenge
  • Clocks Contest
    Clocks Contest
  • Woodworking Contest
    Woodworking Contest
190 Comments
I have made it and it work very well thantks to you ! i have the LM386-1 and only 3 accus of 1,5V !! i have put the tiny magnet in plasticine.
please can you help to make coil necklace how mich turn i need for the best result
do you have ohm meter?
i didnt remenber very well but i think 60 meters of 0,28mm varnish copper wire , dt forget to take off the varnish before soldering
Well, this is not my original idea. I saw pictures of this sort device on ebay. Then I made a prototype. And it works. You can search the keyword
Invisible headphones or invisible earphone on ebay. There are two types of invisible headphones. I made the cheaper version which use a magnet as the
in-ear piece.
Hi . How did you determine the resistance and number of turns for the coil?
whats the difference between LR386 and PAM8403 amplifier. Can I use it alternative of LR386.
https://www.instructables.com/id/PAM8403-6W-STEREO-AMPLIFIER-TUTORIAL/
I wonder if you could create a tooth cap for the magnet so it'd vibrate through your jaw and you'd hear it that way.
I bit one and it worked. Mines from ebay, the volume is quality of sound is poor in the ear.
hey the bigger the magnet the bigger the sound?
Hi Frank. Is there a way to add a Mic to it. In order to use it on a phone and not an MP3. Nothing illegal about that lol cuz it's for 10$ on eBay.
Please you can hep me my invisible head phone is didnt worked ??
What the problem ?
(i am sorry for english iam syrian )
it's a mess out there dude,, and there is a possibility that u have shorted ur IC..
hi,,,,brother can u tell me,,all that name of parts u used here,,,,,thanks in advnc
My device is not working ??? I connect points 2 and 4 and and put all negative point on 4 .
you can isolate pin 2 just for the "negative/ground" input, and don't connect it to other ground connectors ;)
I have heard that someone doing the same but thоse headphones run on a one battery only (9v)
do you have an idea, or just a scheme for this type
Their tiny earpieces rest on the outer ear or need to be inserted into the ear canal. Ultracompact and lightweight, earbuds are the most portable of all <a href="http://www.latestone.com/headsets"> Earphones</a>, and they can provide excellent isolation from external noise when paired with a well-fitted tip.
I made it! I used abot 60 meters of 0.25 Coil, but i must say it is very quit. If you gold your finger on the magnet, u can hear it "clearly" and louder. All in all it was very easy.
