Make Your Own Alien Atomizer From Fallout 3
Published
Introduction: Make Your Own Alien Atomizer From Fallout 3
About: I like to cosplay and always make my costumes and props. I also do game design and am designing an online game called Doomsday Online. It is in beta and is free to play. I've used this site for a long time, ...
Normally, I won't upload multiple creations in one setting, but I think this will be a fun build to accompany the disintegrator. Next I think I will do laser weapons :D This will be comparable with the alien power modules from my disintegrator, so be sure to make more!
Step 1: Cylinder
Take a spray paint lid and dremel a hole through the center. Glue a tube of pvc equal to the length of the cap inside the hole. Trace the lid on cardboard and cut out. Finally, glue the cardboard to the lid.
Step 2: Handle
I used an old airpsoft magizine, trimmed the top, and glued it to a battery pack. But if that's too much of a hassle, just cut it out of wood. Glue the cylinder to the top of the handle as shown.
Step 3: Other Cylinder
Repeat the first step, but don't dremel the hole or add pvc. Then take the 2nd cylinder and glue it to the bottom of the handle.
Step 4: Body Peices
Cut a block of wood in half and glue each piece to the cylinders. Be sure to put them in the middle.
Step 5: Supports
Cut two supports out of cardboard and glue them on. Make sure to cut one short for the module port.
Step 6: Barrels and Carriages
Cut two pieces of pvc, one longer than the other and glue them to the wood like barrels. Then cut two pieces of cardboard, fold them equally, and glue them to the inside of each piece of wood.
Step 7: Tube
I used surgical tubing, but you can improvise, to make the tube. Thread it through the top carriage. Glue the other side to the handle.
Step 8: Details
Again, I used pennies, but washers are cooler. Glue one to each support point. Also, cut out two large circles and glue them to the bottom cylinder.
Step 9: Paint!
Paint and add glowing tape!
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Stick It! Contest
      Stick It! Contest
    2 Discussions
    ive heard of alien weapons in fallout but not this one what does exactly
