loading
In this project I will show you how to combine a Raspberry Pi Zero with a couple of complementary parts in order to add an ambient lighting effect to your TV which enhances the viewing experience. Let's get started!
Step 1: Watch the Video!
The video gives you all information you need to build your own ambient lighting. The next steps will contain additional information to make the project even easier to recreate.
Step 2: Order the Components!
Here you can find a parts list with the most important components that you will need.
Amazon.com:
APA102 LED Strip: http://amzn.to/2hVy8yp
1x HDMI Splitter: http://amzn.to/2gYYWfL
1x HDMI 2 AV Converter: http://amzn.to/2gYSpRW
1x Raspberry Pi Zero: http://amzn.to/2gYWRjN
1x 5V 8A Power Supply: http://amzn.to/2gP1nOl
1x USB Video Grabber: http://amzn.to/2gZ0FSd
1x USB Hub: http://amzn.to/2gOMUlB
1x WiFi Dongle: http://amzn.to/2hx7SJW
Wago Terminal: http://amzn.to/2gOTCIv
Velcro Tape: http://amzn.to/2i39QyH
Ebay:
APA102 LED Strip: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x HDMI Splitter: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x HDMI 2 AV Converter: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Raspberry Pi Zero: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 5V 8A Power Supply: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x USB Video Grabber: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x USB Hub: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x WiFi Dongle: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Wago Terminal: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Velcro Tape: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.de:
APA102 LED Strip: http://amzn.to/2hVn6ZZ
1x HDMI Splitter: http://amzn.to/2hN2DDC
1x HDMI 2 AV Converter: http://amzn.to/2hN4t7e
1x Raspberry Pi Zero: http://amzn.to/2eFXSgR
1x 5V 8A Power Supply: http://amzn.to/2hN3zYs
1x USB Video Grabber: http://amzn.to/2hMSRkC
1x USB Hub: http://amzn.to/2hVwkWl
1x WiFi Dongle: http://amzn.to/2hMZOlW
Wago Terminal: http://amzn.to/2hVrZSX
Velcro Tape: http://amzn.to/2hVwUDl
Step 3: Download / Install the Software
Here you can find the links to the OS for the Raspberry Pi, as well as the HyperCon tool and the Win32DiskImager software.
Raspberry Pi OS (Raspbian): https://www.raspberrypi.org/downloads/raspbian/
HyperCon: https://hyperion-project.org/wiki/HyperCon-Informa...
Win32DiskImager: https://sourceforge.net/projects/win32diskimager/
You can follow the guidelines I mentioned in the video but you can also follow the installation guidelines of the Hyperion website: https://hyperion-project.org/wiki/Main
Step 4: Finish the Wiring!
Here you can find the wiring diagram as well as pictures from my completed wiring. Feel free to use them as a reference.
Step 5: Success!
You did it! You just added ambient lighting to your TV!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
<p>Thanks for this tutorial.</p><p>I made it but I have a problem with the baudrate.</p><p>I did it on a 55&quot; tv, I have a total of 224 LED on it, but sometimes the strips are flickering. When I change the baudrate it's better but I don't know how to get the good value. Do you know the way to calculate the good baudrate ?</p><p>Thanks</p>
<p>Maybe it's not the baudrate in fact.</p><p>When I set the LED full white it's flickering a lot and it I measure the voltage at the end of the strip I get about 2.5V. I reduce the luminence gain to 0,5 but it doesn't change the problem.</p><p>Any idea ?</p>
<p>The photos don't do justice to the result :) You can catch a glimpse of the RP3 on the bottom left of the second photo. Everything stocked there with adesive velcro. A few changes from the tutorial:</p><p>- I only use the power brick for the leds, the rest of the devices (splitter, converter and soon HDMI selector) is powered by a multi-charger I had laying around. This may change in the future as the power supply should be stable enough to power everything, but it was simply easier that way.</p><p>- All strips are in series</p><p>- RP3 instead of 0 so no need for wifi dongle. The CPU occupation is under 10% (at the worst case) while running hyperion in composite aquisition mode.</p><p>Good luck everyone !</p>
<p>i have WS2801 leds do you think that will work insted of APA102. they are basicly the same leds or am i wrong?</p><p>main question will it work?</p>
It will work. Hyperion uses the FastLed library (http://fastled.io/) that list WS2801 as compatible leds. Also, Hypercon (the configuration tool) has an option for this led type.<br><br>Good luck !
<p>thank you :) i have connected everything up now but when i tupe sudo lsusb</p><p>i only get Bus 001 Device 005: ID 1b71:3002 not /dev/video0 and yes my grabber is utv007 chipset<br><br>any solutions?</p>
<p>I'm not a Linux expert and the hardware management is worst :/ What distribution are you using on the Pi ? I installed the standard Raspbian, then Hyperion using Hypercon remote install feature from my desktop. </p>
I made it on my 110&quot; projector screen and it looks awesome thanks for the tutorial
<p>Hello, I had to connect the Pi ground to my 10A power supply ground for the signal to be correctly passed to the leds. I hope it helps (a bit late I assume)</p>
<p>I haven't used a Pi before so I don't know how the compatibility between the models works. Would I be able to do this project with a newer model like the 3 so I can have wireless capabilities built into it, with the video input still working with HyperCon? My idea is to run other stuff at the same time from the same Pi board, like Alexa, which I'm guessing I would need a higher end board for than the Zero.</p><p>Thanks for this tutorial by the way, it was the inspiration I needed to take a stab at these electronics boards!</p>
<p>Hello, I just did it with the Pi3, no major issue to report (colors are a bit too &quot;intense&quot; sometimes, but that's just a grabber/color setup) and for sure I use the integrated wifi a lot with the hyperion remote. I'm planning to add a remote controlled HDMI switch to, well..., switch from my various inputs :D</p><p>As a general rule: whatever a Pi 0 can do, a Pi 2 or 3 will be able to do it, but faster. The system images to run are different but that's about it.</p>
<p>Hi Great Scott. Awesome tutorial. I got the LEDs in today and I've been playing with it for a while now. I saw that other tutorials for APA102 use a voltage shifter for the data and clock, but you're not using one. I have 5V (10A) set up alright, as well as hyperion working, but it seems like the signals are not going through properly... Ideas?</p>
<p>Did you checked whether there is a signal output?</p>
<p>Hey guys i wanting to make this for my PC dual monitor setup.</p><p>just wanted to know that do i need exactly this same components sine it will be connected to my PC not TV?</p>
<p>Hi! Great vids! I have a few questions. In your previous build you connected directly from the end of each strip to the next one including the 5v and GND, Why do you do it differently this time?... Also, besides the PI and the Strip what other component needs an special dedicated source of power?... Sorry for the other stupid question but I do not know how these wago connectors work, my logic says it is for sharing the inputs/outputs (power or ground) but I am not that great at electronics so i have to ask, if so can i put one after the other (in case i cant get the 5slot connectors you use)?</p>
<p>I'm not greatscott, but I think why he separated all +5V and GND per strip is to maximize the voltage each led gets, of course at this length, the voltage drop wouldnt be drastic anyway if he connected all in series, could be other reasons aswell why he did that. Also you can connect share source from one wago to other, if you dont have enough space, I had to do this once at one project from cheap employer, who only had 2 and 3 terminal wagos. It's not pretty, but works.</p>
<p>Is it possible to make without using any entertainment system? So directly from TV?</p>
<p>Hmm.. I was going to try and find a splitter for DisplayPort (I wantt ttis for a gaming setup), but then I realized I could make my computer miror connections to HDMI anyways. Isn't PC Nice.</p>
<p>Also, if I had to use a splitter I'd fear some input delay; not sure how much if any though.</p>
<p>How about the delay from video and light? This ain't gonna be real time since there's a converter from digital to analog and the RPi also needs to process the input data to show the correct image colors.</p>
<p>Can you skip the hdmi to av, and the videograbber if you use a PI2 or a PI3?</p>
To my knowledge the pi does not have a HDMI input, just output. I think you have to use a grabber. There's HDMI grabbers but you need to check they are compatible with the pi, but if it is you can at least skip the hdmi-av conversion
Can you tell me what Wago terminal sizes and amount you need.
Anyway to use the hdmi outpout from the tv and
<p>HDMI output?</p>
Oops <br>It was late at night and just now i was thinking what have i asked:(<br>I want a way to scan thecorners on thetv regardless where the signal is coming from.<br>I have android tv i use youtube/kodi how can i make this happen?
<p>Do you know any way to adapt this project to a dual monitor setup?</p>
<p>looks good :) Have you considered using some LED strip diffuses, to even out the hot spots? </p>
<p>Not yet. I like the way it looks right now. </p>
<p>Thank you Jeremy for making me purchase stuff with every video you make!</p>
About This Instructable
15,454views
199favorites
License:
Bio: Awesome Electronics Tutorials, Projects and How To´s
More by GreatScottLab:Make Your Own GPS SMS Security Tracking System DIY Portable LED Panel TV Remote Becomes an RF Remote || NRF24L01+ Tutorial
Add instructable to:
