Step 3Aquire the necessary parts
Be sure that the water heater does not leak and has a working heat element. The element is very very important since you will be heating the oil up prior to making the fuel. You will also want to keep it warm when it settles, in addition to when you remove the glycerin.
You will need about ten feet of 3/4" clear PVC flexible hose. (+hose clamps)
The plumbing materials I used were:
-3 tee Joints 3/4" x 3/4" x 3/4"
-2 3/4" Unions (these are so you can disconnect your pump without disassembling the whole thing.)
-2 1"-3/4" reducer couplings
-1 3/4" 90 degree elbow
-7 3/4" Ball valves
-11 3/4" x 1.5" male connectors
-1 3/4" x 2" male connector
-2 1" x 1.5" male connector
-4 3/4" to 3/4" Male adapters (Barb to MPT)
-2 to 3 lengths of 3/4" pipe (this depends on the size of tank you're using. Lows, the one by me anyways, will cut and thread piping for free. Measure twice, so you only have to pay once.)
-You will also need tape to seal each fitting.
You're going to need some way to secure your processor. We used some adjustable straps and some connectors. Certainly you can secure it however you like, but this best suited us since we plan on replacing the tank very shortly.
One other thing you'll need to get acquainted with are carboys. You can some good ones here. You need one with a cap that has a 3/4" female threaded port. This will make your methoxide mixing tank, so you will want it to be air tight.
Lastly, you will need 2 power cords. Or just one if your water heater is already wired.
Add Comment
