Introduction: Make Your Own Custom Glowing Etches
I will be showing people how to make a glowing design track-board-thing with only a few things. The idea for this came from this instructable by SLIMGUY379
Step 1: Materials
1. Some 1/4 inch(or thicker but 1/4" is best) plexi glass. You will only need 1.5"/1.5" pieces
2. LEDs. Small 1/8" ones. Any color.
3. A sharp pointy object
4. A paint stirrer or other piece of wood/plastic 1/8" thick.
5. some conductive tape. Aluminum foil and glue should work.
6. 1/8" drill bit and drill
7. Power supply right for the LEDs you have. I used a 4.5v wall transformer and a 100 ohm resistor.
Step 2: Make the Stand
1. Put some conductive tape on either side of the paint stick/other object. (going across the long way on the biggest sides towards one medium sized side of the stick/other object.)
2. PARTY!
3. clean up.
4. Find a way to make it stand up with the taped edge up. For now I'm using a vice.
5. Hook up a power supply to the two pieces of tape. (+) to one side and (-) to the other.
2. PARTY!
3. clean up.
Step 3: Carve the Plexi Glass
Use the sharp pointy tool to carve your design into the plexi glass. It doesn't have to be deep. I have a few tips for this process.
- To separate the paper from the plexi glass easier, soak them in citri-solve for a minute or so.
- Put a picture under the glass.
- Have only one light on when you are carving.
- line up the shadow of the tip of the carving tool with the line on the paper you want to carve.
Step 4: Drill....
Drill a 1/8th hole in the bottom of your design. Doesn't need to be very deep. This step can be done at any time...
Step 5: Enjoy!
Put the LED into the hole in the plexi glass and put the whole thing on the stand. Enjoy!
- Try different colored LEDs
- Take pictures of your designs and post them in comments!
