Make Your Own Flexi-Ties (Soft Twist Ties) by bobzjr
Featured
Step 1: You only need a few items.
MATERIALS
You'll need some solid core single-strand wire.  I recommend 8 gauge copper.
STRANDED WIRE WILL NOT WORK.
Single strand is best because it is stiff, pliable and can hold a shape.
You can probably use coated or uncoated wire.
I just happened to have uncoated left over in the garage.
You will also need some soft rubber hose
Notice that you want a hose that is somewhat soft and flexible.
I found some while cleaning the garage today.
The hose I have appears to have an outside diameter of about 3/8 inch.
Looks like the hose wall is about 1/8 inch thick.
And finally the hole in the hose appears to have an interior diameter about 1/8 inch.
These are approximate measurements.
I believe this hose is a lawn mower fuel line hose that I got from Home Depot.
TOOLS
You will need some needle-nose pliers.
Also you will need some wire cutters.
ASCAS says: Apr 24, 2012. 9:17 PM
NIce! Great Idea!
ilpug says: Apr 18, 2012. 2:25 PM
I like it.
Raitis says: Mar 21, 2012. 1:24 PM
Correct me if I'm wrong, but doesn't copper eventually harden when being worked on (bent, hammered, etc.)?
nailbreak says: Mar 23, 2012. 3:37 PM
Of course it can harden, but... if you need something you are going to open all the time, then a slip-clasp would be better. This idea is great for a quick cure, or for seldom used.
Plus, I can see other uses: Plants, quick Hangers in the garage, my Computer cables and even a fancy Cup holder.
bobzjr (author) says: Apr 3, 2012. 6:10 AM
nailbreak, Thanks for the note. Also, what is a "slip-clasp"?
nailbreak says: Apr 4, 2012. 5:17 AM
Thanks for making me clarify - The "slip-clasp" is not the proper name, I should have used the words "carabiner hook"; and... thanks again, as I realize now how important it is to use proper words that can then be searched for clarification. This is good to learn now, being so new.
bobzjr (author) says: Apr 8, 2012. 5:51 PM
nailbreak - thanks for clarification - I really like your suggestions of the carabiner. If I give that try - I'll post something on it...(and credit you with the idea)
bobzjr (author) says: Mar 22, 2012. 1:04 PM
Raitis, I believe you are correct. I think any non-ferrous metal will harden by working it. So, I guess that could present a problem. Would the possible issue then be:
  1. Hardening of metal which makes it more difficult to bend?
  2. Breakage of the metal when trying to bend?
I suppose they would be issues that would come into play if the tie is used frequently.  Historically, I have not been a high-frequency "tie-untie" person...
I may give it a test drive and report later.  Thanks for the reminder...
rimar2000 says: Mar 19, 2012. 4:16 PM
Good idea.
I think that iron wire (galvanized or not) can work too, although it endures less plastic flections before breaking. The advantage is its price, far cheaper than copper wire.
MaryT8M says: Mar 19, 2012. 5:28 AM
WOW good idea......I too needed something like this the other day, and couldn't make a trip to the store.....I ended up using a bungie cord, and it really didn't work too well.
Thanks for the instructable
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
