I have called industrial distributors trying to find this type of item in bulk.
After many calls, I could not locate it, so I thought I could just make my own!
This is my first instructable.
Remove these ads by
Signing UpStep 1: You only need a few items.
STRANDED WIRE WILL NOT WORK.
Single strand is best because it is stiff, pliable and can hold a shape.
You can probably use coated or uncoated wire.
I just happened to have uncoated left over in the garage.
You will also need some soft rubber hose.
Notice that you want a hose that is somewhat soft and flexible.
I found some while cleaning the garage today.
The hose I have appears to have an outside diameter of about 3/8 inch.
Looks like the hose wall is about 1/8 inch thick.
And finally the hole in the hose appears to have an interior diameter about 1/8 inch.
These are approximate measurements.
I believe this hose is a lawn mower fuel line hose that I got from Home Depot.
TOOLS
Also you will need some wire cutters.
Visit Our Store »
Go Pro Today »
Plus, I can see other uses: Plants, quick Hangers in the garage, my Computer cables and even a fancy Cup holder.
I suppose they would be issues that would come into play if the tie is used frequently. Historically, I have not been a high-frequency "tie-untie" person...
I may give it a test drive and report later. Thanks for the reminder...
I think that iron wire (galvanized or not) can work too, although it endures less plastic flections before breaking. The advantage is its price, far cheaper than copper wire.
Thanks for the instructable
